Question about Kenmore 19233 Computerized Sewing Machine
My Kenmore 19233 refuses to zig zag stitch past 2mm wide. At 2mm it is a reliable stitch, moving toward 7mm it is a straight stitch with one or two zig zag blips.
Machine is new, all other stitches work, changed to a new needle, checked with a new bobbin. Tension is at 5, bobbin is still at the factory adjustment. Cleaned out the fuzz in the bobbin case
Posted by Pam FinGado on
Ann
    Habit-Forming:
    New Friend:
  • 20 Answers
Do you have it on zig zag or maybe it is in one of the hem stitches. Make sure you have not selected a special stitch. Sometimes with a small width setting it looks like no zig zag, then when you increase the length you see it is not.
Posted on Oct 21, 2014
5 Related Answers
Peter Bradshaw
  • 106 Answers
SOURCE: wont change settings
Take out the needle, tighten the needle clamp screw.
Select the zigzag setting plus the largest stitch width, run the machine quite fast for a few seconds. Turn the hand wheel so the needle bar is at it's lowest, turn power off, get hold of the needle bar and move it side to side half a dozen times.
Turn on power, run the machine again as before.
Go through all stitch type settings zigzag/straight etc and run the machine in each setting.
If after all that the problem is not solved I am afraid you need a sewing machine tech to have a look at it.
It would be interesting to know the make of machine and how old it is, plus when it was last serviced.
Best of luck
Rob
Posted on Mar 28, 2008
Anonymous
  • 46 Answers
SOURCE: zig zag stitches are not holding
When ever a machine is jamming up the bobbin thread, it is a result of your top tension. It is either set to low (under 4), or the thread has come out of the take-up lever. Check your threading, fromt he spool pin, down to 2 and up to 3. Three is the take up lever. From the take-up lever down to 4. Set the thread behind the thread guide and thread the needle form front to back. Low quailtu thread 9dual duty or all purpose) can also create this problem.
thanks,
Bonnie
Posted on Sep 02, 2008
Anonymous
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
Anonymous
SOURCE: top thread tension tight
March 12, 2009
kenmore 385.17922
i have started using my machine again (after several years) and am doing patchwork.. all has been fine, and suddenly the bottom thread (bobbin) is looping. i've adjusted the tension nob from 4 (where i had it) to 5...back to 4.. 41/2....3 1/2....5 1/2... on and on and the bottom thread still keeps looping.
i've read and re-read the manual...and the only suggestion it gives is to adjust the tension button.
it's not working...... what else can i try??
thanks
eva
Posted on Mar 12, 2009
Anonymous
SOURCE: Kenmore 1914 Zig Zag needle wont move side to side
I have this machine and love it too. I am glad to see I was passed down a great machine from a great person. I do not have the arm cover to the machine or any cams, extra feet or Manuel. I have made do for many years but would like to know where to get parts.
Posted on Jun 10, 2009
HOW DO YOU CHANGE THE STITCHING FROM STRAIGHT TO ZIGZAG
Check that your sewing machine is even capable of zig-zag. Some machines are straight-stitch only.
Consult your owner's manual.
If your machine can do zig-zag, somewhere there is a dial or setting called "stitch width" that will determine how wide the zig-zag will be.
May 21, 2016 | Sewing Machines
My zig zag stitch works well at 2mm but any wider and it is unreliable and basically a straight stitch. Does not make a 7 mm wide stitch
It needs servicing. Although Janome makes wonderful sewing machines, the newer machines have parts that are not metal. That's the nice thing about the old singers and kenmores. They have all metal parts, so they don't break or wear out much. Take it to a repair shop.
Oct 20, 2014 | Janome Sewing Machines
Kenmore 19233 very new. When using the zig zag stitch, only reliable at 2mm or less. Increasing width to 7mm results in a straight stitch with a few zig zag blips.
The hook timing is out. If it's very new I'm assuming it's still under warranty. Take it to the place you purchased for repair.
Oct 20, 2014 | Sewing Machines
Kenmore ultra stitch 6 Model 13402
If the machine is not zig zagging when you select zig zag it will mean the selector finger needs adjusting which is a shop job
May 26, 2014 | Sewing Machines
Kenmore 91223 zig zag stitch is roaming all over the place
Your feeddogs are not engaged. There will be a button or lever that controls this. You will just have to find it and flip it. Could be on the ends of machine or the front bottom edge. If I could see a picture of machine I could help
Oct 15, 2017 | Kenmore 19233 Computerized Sewing Machine
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Kenmore 19233 Computerized Sewing Machine Logo
204 people viewed this question
Top Kenmore Sewing Machines Experts
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
