Upon turning on my TV, the channel I was last on (radio 1) works (sound and picture). However, when attempting to change channels, the screen simply freezes and there is no sound. Yet, the menu button still works and I can change my TV onto different modes (on Toshibas: 1,2,3, HDMI1, HDMI2 and PC) yet the channels within DTV will not work. Please help!!!
SOURCE: Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
SOURCE: Toshiba 50HP66--can't change channels anymore
I had this problem. Unplug it while it is powered on. Worked for me.
SOURCE: need help
ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
SOURCE: SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
I hope that helps.
