Question about HP Officejet 4500 All-in-One - multifunction fax / copier / printer / scanner color
My printer does not eject the printed page fully and starts printing the second page over the bottom of the first. How do I rectify this, please?
See above
Posted by Ian George on
bosy1
  • 76 Answers
In your Setings on the print page or setup the print page, press the button Defoult, or Defoult all Setings. That will fix your problem.
Good luck
Posted on Mar 02, 2015
My Officejet 4500 does not eject a printed page fully, causing the next page to overprint the bottom of the previous page.
Sounds like the printer is set up to print a smaller size paper than the sheet size you are actually using. Measure your paper size, then go into the printer settings and choose the sheet size that matches.
Oct 20, 2014 | HP Officejet 4500 All-in-One Inkjet...
Printer chews up paper when it is printing. Can this be rectified?
Step 1: Take half test page check is there any symptom what you are getting? If yes replace with another cartridge check...( How to take half test: Give fully mattered print command while printing switch off the power remove cartridge take out printed paper check the printed matter on page) Step 2: If found cartridge is OK, 95% suspected Teflon sleeve( a cylindrical sleeve which is coated grey colored Teflon), replace it if available if not replace with new fuser assembly..
Nov 18, 2011 | HP LaserJet 3015 All-In-One Printer
A minor problem, but annoying at the very least. The print server works very well except for the last page of print. The printer does not fully eject the last sheet of printed paper. If it's page 3 of...
change paper size setting as the printer may be set to a shorter page and that is why it is not ejecting
if nothing works then always print an extra page
it will run through the printer untouched
Apr 06, 2017 | IOGear GPSU21 Print Server
Printing Problems
What type of print job are you sending to the printer.
This sounds more like a data stream problem than a hardware failure.
What printer language are you sending to the printer.
Can you attach a print to file that fails on your compute for me to analyse?
What model printer are you using? What PC? What operating system.
Also, make sure the feeder rollers on the exit side of the printer are clean and round. As in not pitted or very slick.
May 02, 2009 | Office Equipment & Supplies
I just installed my new printer HP F4280, when gives print command in MS office it give error message MS office has stopped working
Hi Ahsan & Guest,
Thanks for sharing the problem with me.
Please first check printer installation:-
Start --> Printers and Faxes --> Right Click the printer --> Properties --> Print test page.
Problem might be Lose cartridge, Lose cable connections, Paper Jam, previous aoverloaded print que. Please Rectify all this.
There may be a hardware problem with printer itself please take help of printer technician in that case.
If this works, then start MS word, type something on page.
Click on print and select the right printer and print. It will work GoodLuck
Dear Guest, this problem might be in printing the web pages, please select all what you want to print or select nothing before printing.
Please see print preview to make sure that what you are going to print is rightly selected.
Thanks
Zulfikar Ali
[email protected]
09899780221
Jan 22, 2009 | HP DeskJet F4280 All In One Printer InkJet
White lines across the printed page - C1100 laser colour printer
Can you just reinstall your driver again,just to confirm that there is no driver problem.
Jan 02, 2009 | Epson Aculaser C1100 Printer
Page Eject WHen Printing Word Docs
change the paper size in the printer properties for example to a4, or to lettersize.ehat the actual sizeis.or the problem is with paper feeder gears. try cleaning them.
Aug 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
May 23, 2008 | HP LaserJet 5550 Printer
LED BLINKING
Replace the communication cable (parallel cable).
Dec 11, 2007 | Epson FX 1170 Matrix Printer
Paper eject problem
Dissconnect printer from usb port. Go to add/remove programmes and uninstall the printer driver. Insert your printer driver cd rom and re-intall driver and connect printer when prompted. This should work
Dec 16, 2006 | HP DeskJet 940c InkJet Printer
HP Officejet 4500 All-in-One - multifunction  fax / copier / printer / scanner   color Logo
76 people viewed this question
Ekse
efs_perpends
efs_perpends
