Hi
if you are aking on how to soft reset the system to factor settings then the code is
*#7780# This will soft reset your phone all data, like contacts, calendar and notes, are not removed It will only reset the phone settings, such as profiles, themes and shortcuts.
*#7370# This will also reset your phone all data, like contacts, calendar, notes, profiles, themes and shortcuts are removed. The default lock code is 12345.
there is another way to hard reset you phone completly
make sure battery is fully charged and first switch off the phone then
hold the Green button + *button + 3button and Power button and wait till Formatting appears on the screen
all data will be lost on the phone (not memory card)
cheers
pls rate if it was any help
SLS
Reset to factory defaults ( *#7780# ) : Restores settings but preserves user data (photos, 3rd party apps etc)
Reset ( *#7370# ) : This reformats completely the C: drive. All applications and files stored on this drive will be lost and clean default files will be rewritten.Back up all data before reformatting
