LeapFrog Clickstart My First Computer Logo
L
Larry Shudark Posted on Oct 20, 2014
How do I make my print bigger in my e-mail and in other places?
Dave Wood
Level 1:
  • Contributor 26 Answers
  • Posted on Oct 20, 2014
Dave Wood
Contributor
Level 1:
Answers
26
Questions
6
Helped
4671
Points
80
Go to top right corner of top tool bar, click on 3 parallel horizontal bar symbol, menu opens, oom options select what you want.........
Simples !! Win XP
When I reply to an e-mail on OUtlook 2010, the font size is very small - and I cannot read the original or what I am typing. Any ideas on how to restore the normal size
Having trouble seeing that small default font of Microsoft Outlook emails? There are three ways of making Outlook email text bigger.
The first includes increasing the text size of the outgoing email messages.
The second includes increasing the text size of messages that are replied to or forwarded.
The last includes making all the text of incoming emails larger as well.
Go to the Tools menu and select Options.
Click the Mail Formats tab and then click Stationary and Fonts.
Find the Personal Stationary tab, then find and click the Font button located under the New Mail Messages heading.
On the Font tab that appears, there will be a variety of options including changing the type of font, style, size and color.
Find the drop-down menu that is under the Size heading and select a bigger number.
Click OK and the new setting will take place the next time a message is composed.
Replies or Forwarded Mail
Find the Personal Stationary tab, then click the Font button that is located under the Replying or Forwarding Messages heading.
Click OK and the new settings will take place the next time a message is replied to or forwarded.
Incoming Email Messages
Look for the Display Font heading on the Personal Stationary tab and increase the size the size of the font by selecting a larger number.
This will increase the text size for all plain text incoming email.
However, it will not increase the text size of incoming HTML emails.
Set the option to read all incoming email as plain text if it is necessary to increase the text size of all incoming emails.
To do this, go to Tools, then click on Options, then look for the button that says Email Options and click Read all Standard Mail as Plain Text.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Increase size if print in e-mails
Did you do some settings while it is going to print?
You can go to preview first, then set bigger font or format.
electronics wholesale
2answers
My scansoft pdf software is not reducing to a small enough file to e-mail it is at the smallest resolution,
Apart from getting an emails account that allows bigger attachments there may be another way.... In the document ensure the smallest "Font" is used,any images are thumbnail versions and perhaps even try compressing it before you send with winRAR or the like
When I print incoming e-mail letters are too small. How do I make them bigger?
  1. Choose Tools | Options, and switch to the Mail Format tab.
  2. Make sure the Use Microsoft Word to edit e-mail messages box is not checked.
  3. Click the Fonts button.
  4. On the Fonts dialog, make your selection with the Choose Font button under When composing and reading plain text.
  5. Click OK until you return to the main Outlook window.
Bulk mail inde
Put spaces in your type to move it over if you cannot move the margins. You might also be able in print options page setup to indent the margins or paragraph so it prints inside the page.
Print is to small i need it to be larger but i dont know how!
Open the document you are trying to print
Look at the top tools bar
Take the cursor and place it over the writing on the document
The type of font and size should appear in the boxes on the tools bar
If you want to make them bigger
Highlight all of the text which is to be enlarged
Go to the box and select which Font you require ie Times New Roman
Go to the next box and select the Font Size ie 12
That will make the writing bigger and will come out of the printer at that size
I received a photo through e-mail. It is very large. I saved it to My Pictures and moved it to a folder in Kodak easyshare, but I can't print it. How do I make it small enough to print as a 4 x 6"?...
whoa!
Large means 2 completely different things.
1] large file, has high resolution & takes up Megabytes [some e-mails will choke at this.
2] physical size of print.
what these 2 things have to do with each other is: the bigger [1], the better [2] will look.
This is because with more pixels to work with, the ultimate image is better.
The available memory in your computer may not be enough to handle the entire image. Add memory to the computer or send the picture to yourself with a program that "resizes" like outlook, OR have the original sender do the last step.
It is possible that you can change the bit depth [number of colors] on the image, but this isn't recommended for output quality.
2answers
Epson CX6600 printer error
Remove the Print ink cartriges. Get a new bottle of windex and using a eye dropper place some windex on the post where the ink sits. also place some windex on the area that the printer uses to clean the print heads. leave it for an hour or two, You might have to do this several times. If problem persists do above treatment and leave over night. Hope this helps.
Top LeapFrog Toys Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
