SOURCE: Bottom right side door hinge
http://www.jennair.com/content.jsp?name=parts_stores go to this link and you can get the part u need
SOURCE: I have a co29ff and the bottom hinge to the
The part number would depend on the color of your icemaker. Here are the part numbers for the entire hinge assembly:
11899-S-KIT (hinge assembly bottom R/H white) $22.11
11899-S-BLK (hinge assembly bottom R/H black) $22.19
11899-S-SS (hinge assembly bottom R/H stainless steel) $36.41
I found these parts on www.allbrandonline.com You can also purchase separate parts of the hinge assembly.
I am sure there are other sources. I hope this helps
SOURCE: my frigidaire door shelves broke... how to get them fixed cheap?
Order them from the sears.com website.
SOURCE: I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
SOURCE: I have an lg refrigerator
Hello Cyndi. Go to this link, and select the parts you need. http://www.repairclinic.com/Appliance-Parts?s=t-LRBC22522WW-%3d%3dc71
Joe
