Question about Fisher and Paykel GWL11 Top Load Washer
My FP GWL11 washer will not fully fill with hot water on the "hot" cycle. It will start with hot water, but then the water turns to cold for the rest of the filling.
At the beginning of the wash cycle on the "hot" setting, hot water will start to fill the tub. After about 2 minutes when the tub starts to fill, the water is cold.
Posted by Sheila Rodgers on
Mohamed Bahha
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
THERMISANCE IS BAD AJUSTEMENT NEEDED BY QUALIFIED PERSONNAL LIKE IRON TEMPERATUR CONTROLLER
Posted on Oct 26, 2014
5 Related Answers
eje006
SOURCE: Slow fill on cold water/Fisher&Paykel GWL11
Assuming you have already done what you said you have done, now it is time to do some real troubleshooting.(Dont worry, if you have gone this far you'll be able to do what I'm going to tell you)
First take the lid off. To do this, open it, and lift up on one side, it should come right off. Now take the control panel cover off. There are two screws on the back side of the washer holding it on. You'll need to wiggle it a bit to get it off. Once the cover is off you should find a plastic bag with a "service" sheet in it. The service sheet explain how to put the machine into the "Test Mode". This is very easy to do and will allow you to check out all functions. One of the test, allows you to check the cold water inlet valve. Assuming your water pressure is good and you have indeed cleaned the screen filter going into the machine you will most likely find that the cold water valve is not opening all the way and will need to be replaced. If your handy with a phillips screwdriver you only have two more screws to take out and the valve assembly will come right out.
Don't think you can swap out the hot water valve with the cold water valve. Fisher Paykel, clever as they are made sure you can't do that. One is a proportional valve and the other is a digital valve. They both look identical but they are not!
If your going to do the repair yourself (you've come this far, why not see it through to conclusion), be sure when you call Fisher/Paykel to order the cold water inlet valve that you give them the serial number of your machine to be sure you get the correct part.
Good Luck!
Posted on Jan 27, 2009
stephanos18
Steven White
  • 144 Answers
SOURCE: Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Cheers
Posted on Mar 25, 2009
William Czarneky
  • 87 Answers
SOURCE: Fisher & Paykel Washine Machine is filling up hot and not cold?
As nice as these machines are, I've read bad things about Fisher & Paykel reliability. It sounds to me like you have a bad solenoid.
FYI, you should leave the water lines on (both hot and cold) all the time, no need to shut them off unless you're unhooking the machine to move it or work on it. The machine should control the temperature itself.
Posted on Jun 14, 2009
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: I have a smartdrive 601 that will not fill start
hot and cold hoses connected backwards
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 22, 2010
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: My Fisher & Paykel GWL11 Washer starts beeping
Hi
The washer is detecting error while it enters wash cycle. You can try and enter the diagnostic mode & check if it resolves the issue. If it doesn't then you would need check for the fault codes.
To enter Diagnostic Mode turn the power on at the power point and off at the console. Press and hold the WASH TEMPERATURE DOWN then press the POWER button. Smartdrive will give 2 short beeps. Phase 1 & 2 Only press ADVANCE button once. From Diagnostic mode press the SPIN buttons until the HOLD and SLOW SPIN LEDs are on, (Diagnostic mode level 3). The WASH PROGRESS LEDs will now display the fault code.
Hope this helps... Please post back if you need further assistance.
Daniel
Posted on Apr 01, 2011
Hi, my machine won't fill with water
It would only be either cold or hot that does not work. Replace the Inlet solenoid under the top panel.
You can use the same aftermarket valves for both (Original FP valves are different, cold is wildly expensive compares to hot). http://www.ebay.com.au/itm/Fisher-Paykel-Cold-24Volt-Compatible-Inlet-Valve-Part-FP420148S-/130833870254?pt=AU_ApplianceAccessoriesParts&hash=item1e764e6dae&_uhb=1
May 28, 2014 | Fisher and Paykel GWL11 Top Load Washer
Water starts and stops, over and over again when filling. After some time, we get trouble beeps and 2 yellow lights, 1 near either end of progress indicator. Machine is a GWL11
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 05, 2011 | Fisher and Paykel GWL11 Top Load Washer
Looking for a water fill sensor for a fisher paykel gw11 The machine starts the cycle just fine, but when starts to fill, the water just trickles out and both water lines are open, whats wrong?
(sorry if this does not fully answer your question!)
John C
Aug 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
Machine squeals when filling
Hi just read your posting.Now what temp of water are you selecting for the wash cycle,is it warm, cold, or hot.Try this,Select hot fill then select cold fill and please reply on whether the squeal stops on either hot or cold fill.Looking forward to your reply.
Oct 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fills to wash, drains but then tub won't fill for rinse cycle;
u need a new cold water valve, if u check the temp of the water while its filling it is mainly hot, or u have the hot nd cold hoses on the wrong way , as all rinses r cold
Jan 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL11 Leaking water
If you cannot see the water leaking from the inlet valves, check the seal just above the water pump located directly under the drum. I am in the midst of awaiting parts to fix this very thing on my FP GWL11. This leak is dripping water directly onto the motor, causing it to trip the circuit breaker during drain/spin cycles.
Note... I have also had to have the inlet valve assembly replaced as well as it was not opening to allow cold water to mix with the hot.
Hope this helps.
Apr 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer only fills with hot water
Probably a bad water inlet valve. To verify, you would have to check continuity at the valve.
http://tclaundryrepair.com/home
Feb 19, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
170 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
