ProntoTec 9 Inch Capacitive Touch Screen Tablet Pc, Allwinner A20 Cortex A9 Dual Core 1.2 Ghz, Android 4.1, 8GB NAND Flash, DDR3 512MB RAM, Dual Cameras, Wi-fi, G-sensor Black Logo
Question about ProntoTec 9 Inch Capacitive Touch Screen Tablet Pc, Allwinner A20 Cortex A9 Dual Core 1.2 Ghz, Android 4.1, 8GB NAND Flash, DDR3 512MB RAM, Dual Cameras, Wi-fi, G-sensor Black
Why wont windows recognise my ptontotec tablet?
Posted by wayne sheldon on
Mark S Smith
    Master:
  • 601 Answers
No drivers installed maybe? Find the Ptontotec website and see if the support page has drivers that need installing to your computer before Windows will recognise your tablety thing
Posted on Oct 20, 2014
I have a prototech tablet and don't remember how to unlock it. I am 71 years old and ha entry used it in a couple of years.
Hello there, you are a good age at 71. Now I'm 88 and have both a Microsoft Surface Pro 4 tablet and a Desktop PC, and both with Windows 10. Now in Windows 10 there is a program called One Note and I record daily, all my activities for the day and in that way I have a record for me in case, I should at some later date want to know something, or in your case, how can I do that task. It is an a amazing program as you don't have to save it as it automatically saved. So for people that age, and you and me are one of them, we forget sometimes quite simple tasks, but with One Note you will always have it there, to refer to at a later date. Now coming back to Microsoft's Surface Pro 4 Tablet, coming with that Tablet is a Microsoft security program called "Hello." Once set-up all your tablet needs is your face to look directly at the Tablet and your facial features will be recognised by the security software and your Tablet will open with Windows 10 on your screen. Easy Peasy!! to say the least. In conclusion, there is nothing on the market that is better than the Microsoft's Surface Tablets. I have had them foe years and no trouble ever. So, hope this can be a little helpful.
Why is my USB reader unmounted?
A Windows PC needs a driver to run a USB memory reader.
The android tablet does not have this driver, as it runs on Linux.
So if t is not recognised, there is noting you can do about it.
I inserted an sd card but my galaxy tablet 2 don't recognise it.
Try un mounting the sd card with the card installed then take it out and teinsert it If that don't work it could be the old format isn't recognized and try formatting it then
Sanei tablet 3it is not running on laptop pc hp
To connect up a tablet with a laptop you need to connect them with a USB cable.
On plugging in the cable with the tablet powered up, you should see two things.
1. A question on the tablet as to whether you want to use memory disc mode or diagnostic(ADB) mode. Choose Memory disc mode.
2. You should see on the PC laptop it recognise that an external device is connected, it may recognise it as a phone or a memory drive.
If neither of these things is happening it is probably the cable at fault.
The tablet should then start providing the pc laptop with the drivers it requires to be recognised. If this does not happen, then the fault is with the tablet and you have to consult your supplier.
You should end up with at least one memory drive which you can browse through with the PC's file manager. The data will be on the tablet.
Unable to download from Google Play due to error code -101.
Hi, its a software problem......it needs to be reloaded, I suggest to have it done by a proper technician.....
Drivers for newsmy t3 ???
If you're still trying to find a solution for using it on Windows, I created a tutorial that should get you up and running: http://pastebin.com/hTJnJMr3
Note that what was done in the tutorial is what worked for me. While it should theoretically work for most people, it can't be guaranteed it'll work for everyone.
My Archos 10.1 tablet webcam is not recognised
Geezus, why did people fall for these things. Once they go bad, you're limited on trying to get yourself out of hot water.
1helpful
The tablet does not recognise my external hard drive
LOL, why do you think HP sold tablets for $699 for 7 weeks then told all the retailers to get rid of them for $99? Those little things are nothing but trouble unless you're buying an Apple.
2answers
Portege m200 wont boot from cd or anything.
look at this page
http://blog.ryantadams.com/2008/02/01/how-to-boot-from-the-network-pxe-boot-with-tftp-and-windows-pe/
it works very good.
Top ProntoTec Tablets & eReaders Experts
Tom Chichester
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a ProntoTec Tablet and eReader Expert? Answer questions, earn points and help others
