I need a torque settings for my 2.4 16v Nissan engine
From repair manual for 1996 KA24E 2.4L engine:
Number bolts as follows:
Exhaust side, front to rear - 8, 6, 1, 3, 9
Intake side, front to rear - 10, 4, 2, 5, 7
Tighten bolts in numbered sequence, five steps.
Step 1 - 22 ft-lbs
Step 2 - 58 ft-lbs
Step 3 - loosen all bolts completely
Step 4 - 22 ft-lbs
Step 5 - 54-61 ft-lbs
SOURCE: torque settings for cylinder head nissan sentra
Tighten in sequence to 29ft.lbs then tighten in sequence to 58ft lbs. then loosen all bolts. Then tighten in sequence to 33ft lbs. then tighten each bolt in sequence 90 degrees then tighten each bolt again 90 degrees
SOURCE: Need Cylinder head bolt torque specs and sequence
Tighten the cylinder head bolts to 50 N·m (37 lb ft) in sequence.
SOURCE: Torque and sequence to Intake Manifold for 3.3L Nissan Xterra 2000
#1 is top right most bolt first, 2nd is farthest to the left on top, #3 is the one down and to the left of # 2, #4 is on top and to the left of #1, #5 is the hardest one to get to and is right in the middle on the bottom, and #6 is only one left which is top middle....
on re-installation you go backwards and torque from 2--22 NM
Since you didn't say which engine you have, I've pulled torque specs for 3 different engines. Also, since I can't include a diagram showing the relative locations of the numbered head-bolt locations, it would be a good idea for you to purchase a vehicle specific repair guide that will show this info.
Take particular note about the TTY (Torque to Yield) bolts used on 2 of the 3 engines shown. It is said that new head bolts MUST BE USED when head is replaced or re-installed to obtain the proper torque.
B2500 4 Cylinder
Torque sequence: --------- ' 10 6 2 4 8
' front ' ' ' 7 3 1 5 9 ' -----------Step 1: torque in sequence to 51
Ft/Lbs Step 2: torque again in sequence to 51 Ft/Lbs Step 3: final
tighten all bolts an additional 90 to 100 degrees recheck final
torque in sequence *** CAUTION ***engine uses Torque To Yield head
bolts (TTY) that permanently stretch during the initial installation.
New head bolts must be used when cylinder head is replaced or
re-installed to obtain proper torque.
B3000 3.0 6 Cylinder
Torque sequence ---------- ' 6 4 2 8 '
' ' ' 5 1 3 7 ' ---------- Step 1: torque to 59 Ft/Lbs Step 2: loosen
in sequence (1) full turn Step 3: torque to 41 Ft/Lbs Step 4: torque
to 73 Ft/Lbs
B4000 4.0 6 Cylinder
Torque sequence --------- ' 5 1 3 7 ' '
' ' 6 4 2 8 ' --------- Step 1: torque cylinder head bolts in
sequence to 26 Ft/Lbs Step 2: torque cylinder head bolts to 56 Ft/Lbs
Step 3: turn cylinder head bolts in sequence an additional 90-degrees
recheck final torque in sequence *** CAUTION ***engine uses Torque To
Yield head bolts (TTY) that permanently stretch during the initial
installation. New head bolts must be used when cylinder head is
replaced or re-installed to obtain proper torque.
Good luck with this job!
