There is nothing to reset the toner will load itself unless there is another problem. Make sure the insert plug from the old bottle came out before you placed the new bottle in.
Please mark this answer as helpful and I will send you the firmware's for both machines. They are different. Please send the Machine code because that is how I will know exactly witch firmware you need.
Have you replaced the developer yet???? It could also be the unit that the toner bottle goes into. There is a paddle wheel inside of it that move the toner and it may have broken up... Good Luck
I believe that you closed all the doors properly...
Well, this may happen because off several things.
I can give you some tips (by steps):
- First you have to make sure that the toner bottle spins (if that doenst happen it could be a faulty clutch).
- Than you need to see if the tonner supply (the green handel that you place the toner) are good.
- After that you just have the TD sensor. This sensor is on the Developement Unit.
Well, i am just giving you a clue. If you do not have thecnical knoledge i advise you to call your provider.
43,000 copies/bottle (based on 5% coverage). For the extremely low cost per page of toner usage, why bother with toner save - you lose substantial quality
The book doesn't really tell you where it is in the machine but if you open the door in front of the copier, look for a white plastic bottle with toner in. Remove the toner bottle from the machine and dispose of the toner bottle and replace it with a new one or dispose of the waste toner. Clean the bottle and replace it back into the machine.
