The crisper drawers have water build up why?
The defrost drain in your refrigerator is clogged and the water is overflowing to your crisper drawers
There is a evaporator coil behind the plastic plate that faces you when you open the doors. the coil behind it may be partially frozen and the drain is clogged just below it. the Styrofoam behind the plate must come with it to gain access to the coil. You must unplug the wires connected on the left before you can work on the drain..
Moisture build up can happen when any of the door/draws are not sealing properly, check for obstructions or seal issues.
Adjust your settings for what you keep in there...and you should be able to solve the problem
SOURCE: Fridge is collecting water under the crisper
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
