Question about Jenn-Air JED8430 Electric Cooktop
Ookware should I buy for a Jenn Air
What type cookware should I buy for a Jenn Air glass-ceramic cooktop?
Posted by ssusan502 on
Anonymous
  • 867 Answers
I would avoid cast iron or nickle pans as they are heavy and coarse. i would recomend a nice stainless set with aluminum bottoms
Posted on Jul 05, 2009
WHAT DO I USE TO CLEAN AN ELECTRIC JENN-AIR CERAMIC COOKTOP; THE BURNT FOOD BUILDUP.
a good product is CERAMABRYTE. it is designed for ceramic cooktops and is a white lotion type cleaner. if there is a lot of burned buildup you may also need to purchase a special scraper with a blade in it. but make sure you smear the cleanser on FIRST or you will scratch the surface.
Oct 24, 2009 | Jenn-Air JED8230 Electric Cooktop
How to repair cracked corner of black ceramic cooktop
Epoxy would not work. If it is a very small chip and is NOT STRUCTURAL or in the heated are you could TRY the adhesive used for rear view mirror to glass attachment.
Sep 13, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Front double burner not working on Jenn Air ceramic cooktop model # JES8750AAB
mostly the problem is the sensor inside the unit but so very expensive to replace,wait to damage the other then buy an new one compare to repair.
tnx gerbee
Jun 29, 2009 | Jenn-Air JED8430 Electric Cooktop
Puiter stain on stove top
ITS NORMAL FOR GLASS CERAMIC, NO KIND OF CHEMICAL TO CLEAN.
TNX GERBEE
May 26, 2009 | Jenn-Air JED8230 Electric Cooktop
My Jenn air range top is becoming stained.
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Mar 26, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
What's best tu glue my cooktop on my granite countertop?
I don't think I'd glue it down permenantly. I just had to replace the ceramic glass on mine (a JED 8430 ABD) after it cracked. Thankfully, it wasn't glued down so I could replace it pretty easily (ordered part directly from Jenn Air). But some sort of seal to keep food out from under the cooktop would be nice. I just wouldn't go permenant. The fact that you have to tape the down draft to the external vent should keep the cooktop in one place (plus its own weight).
Feb 28, 2009 | Jenn-Air JED8430 Electric Cooktop
Stain on burners
Use DeBruce Polish on ceramic cook tops, go to debrucepolish.com
Feb 06, 2009 | Jenn-Air JED8430 Electric Cooktop
Pitted glass cooktop in Jenn Air Model JGC9430ADS
Did you find anything out? We have had our Jenn-aire gas stove for 1 1/2 years and just noticed today that the surface has bubbled in a spot??? I did clean the oven last week.
Sep 10, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
264 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
Michael Thomas
Michael Thomas
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
