During the first few seconds of pump running there is zero water flow. Either there really is no flow at all OR the flow meter is not detecting flow for some reason.
OA means that the sensor is not detecting any heat in the boiler. That means either the boiler is not heating or the sensor or sensor wire is detached from the boiler or the sensor has failed. The sensor is located behind the front display panel stuck in the front of the boiler and it has 2 thin wires in it with push on terminals.
You will probably get some proper help if you identify the exact model. I don't expect "error 2" to mean exactly the same on every model Krups have ever made, narrow it down a bit for us please.
The error code may be different for different models, you need to supply more info when asking questions, the brand is not enough, Krups have made hundreds of coffeemakers.
Maybe you need to supply the model as well, it's not an error code on the models I'm familiar with. Try editing it into your question or ask a new question with the information within it.
