Question about Panasonic Lumix DMC-LZ2 Digital Camera
<!-- from fixya rte -->HOW DO i USE THE TIME DELAY - Panasonic Lumix DMC-LZ2 Digital Camera
My Westinghouse dishwasher is displaying HO2 what does it mean.?
H01-H24 Delay has been selected.so H02 means you have selected two hours delay.
Cancel delay setting if you don't need it.
Time Indicator and delay display:
The time indicator displays the program time and time
remaining for the program
In addition, you can delay the start of the program by
pressing the "+" and "-" buttons before the program is
commenced The delay function is indicated by the letter
"H" followed by the number of hours selected
If you want to change the delay time, you can reset it by
pressing START/PAUSE and then using the "+" and "-"
buttons to select the new delay time, then press START/
PAUSE to activate
Westinghouse WSF6606 User Manual Failure Codes And What To Do In Case Of...
Oct 25, 2017 | Westinghouse Dishwashers
Trying to set switch for 5 minutes , and i only get 30 seconds or 15 minutes
Which brand and model number specifically?
Leviton: 1-800-824-3005
Leviton Decora manual says:
"PR180 operates by detecting motion (such as body heat) within its field-of-view (area of coverage) and automatically switches lights ON. When motion is no longer detected, lights remain ON for a selected time and automatically switch OFF.
Adjustable light and time-delay controls are located on the front of the device."
The manual is not specific about set times.
In any case, the device has off-delay timing circuit, so once infrared heat is no longer sensed, the delay period begins, and once the delay period expires, the device is switched off.
Delay timing circuits are common for many home and industrial applications.
As a general rule, delay timers can be set for different time durations, however the Amazon page that sells PR180 product does not specify available time settings either.
Legrand RW3U occupancy sensor spec sheet says adjustable time delay 15 seconds 5 minutes, 15 minutes and 30 minutes
http://www.amazon.com/Legrand-RW3U603I-Occupancy-Vacancy-Decorator/dp/B005FMLL5G
Delay switches
Here is manual delay-time switch Tork SS20 SS13 where you can 'fine-tune' the delay circuit, but my experience is that exact 5 minutes is not easily set:
http://waterheatertimer.org/images/Paragon-ET-series-243.jpg
GE 15318 switch offers 5 minute, but there is no guarantee that you can get 5 minutes exactly:
http://waterheatertimer.org/images/GE-15318-countdown-timer.jpg
My conclusion is that there are very limited delay-time choices with this model number, or device is defective and suggest to call Leviton.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 23, 2012 | Leviton R01-PR180-1LI Decora 180 Degree...
Candy CDI4545 turn off delay start
Press the key to set the delay start time.This dishwasher can be delayed to start for 1 to 24 hours,and the display window beside the delay key can indicate the remaining time. If you want to cancel the delay start, just press the delay key to make the remaining time become 0.
Dado
May 17, 2012 | Candy CDI4545 Builtin Dishwasher
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
How to cancel delay start
Press the Delay Start button several times until the displayed delay start time is cleared or reads "00". Unplug the machine or flip the circuit breaker to the OFF position for at least half an hour or so to forcibly reset the control if pressing the Delay Start button does not alter or clear the displayed delay start time.
Nov 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Need to make entry time longer . I am able to delete option 10 but can't add option 10. Entry is only 5 sec.
Here is instructions from Installation Manual. I am also attaching links to full Installation as well as User Manuals for your reference at the bottom of page. Make certain to input as 3 digit time - example 45 seconds as 045. Good luck!
Option 10: Entry Delay (Default = 030 sec.)
Determines how much time the user has to disarm the system
after entering the armed premises through a designated delay
door, before an alarm occurs. Beeps sound during the entire
delay time to remind the user to disarm the system.
When turned on, the Entry Delay can be set from 005-254
seconds (030-254 if SIA Limits Option 69 is on). All entries
must be 3 digits. When turned off, the Entry Delay is set to
005 seconds.
Note
For UL listed systems, the entry delay must not exceed 45 seconds.
 To set Entry Delay, press:
1. Add
2. Option #
3. 10
4. Use the numbered keys to enter the 3-digit delay
time.
5. DONE
 To turn off Entry Delay, press:
1. Delete
2. Option #
3. 10
4. DONE
Installation - http://www.homesecuritystore.com/downloadmanual.aspx?mnl_id=334&prod_id=171
Users: http://www.safemart.com/manuals/simon3.pdf
Oct 02, 2010 | GE Security Simon 3 Wireless Home Security...
I love my bc796d and i have had it for about 4 years? My question is concerning the delay when scanning channels and i always keep it on 4 second delay. I would like to have it delay longer and thats where...
Setting DELAY for All Search Ranges
You can set the scanner to have a delay after the end of a transmission before searching
resumes. This slows searching, but helps you prevent missing replies on a frequency.
1:SERVICE OPTION → :CHAIN SEARCH → 3:DELAY
1:NONE
The delay is turned off.
2:1 SECOND
The delay time is 1 second.
3:2 SECONDS
The delay time is 2 seconds.
4:4 SECONDS
The delay time is 4 seconds.
28
5:INFINITE
When the scanner stops on a transmission, you must press RSM to resume
searching.
6: -2 SECONDS
The scanner only stops on transmissions for 2 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 2-second pause.
7: -5 SECONDS
The scanner only stops on transmissions for 5 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 5-second pause.
8: -10 SECONDS
The scanner only stops on transmissions for 10 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 10-second pause.
May 14, 2010 | Uniden BC796D Base Scanner
48DD0284 model I am wanting a part number for a Time delay relay. Dont know how to look up
I looked up information and the unit is obsolete. I also did not see a time delay in the diagram with the original unit. It must have been added later. Post me back and let me know where it goes and what numbers it has on it.
Nov 28, 2008 | Carrier Heating & Cooling
Kenmore 665 Ultra Wash FH141493
Hi daryano
I'm Harvey the Master Plumber
You want to know how to get the delay to work?
Most models work this way: Washing dishes the first time sets the favorites and the next time you start it the favs come on automatically provided you haven't changed the settings. So after the first use just hit delay and nothing else and when the dalay time is up it should work fine.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Aug 31, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Panasonic Lumix DMC-LZ2 Digital Camera Logo
Top Panasonic Cameras Experts
STEVE
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
