Computers & Internet Logo
A
Anonymous Posted on Oct 19, 2014
How can i open my cd dvd tray from my keyboard
Jeff Yousey
Level 2:
  • Expert 35 Answers
  • Posted on Oct 21, 2014
Jeff Yousey
Expert
Level 2:
Answers
35
Questions
0
Helped
27221
Points
119
Don't know about keyboard but you can double click "My Computer" or "Computer", find your dvd drive icon, right click it, and towards the bottom of that menu that pops up, click "Eject" and done.
1 Related Answer
Anonymous
  • 125 Answers
  • Posted on Jul 27, 2009
SOURCE: you did not under stand
If you are able to remove the cd drive form the laptop on top there are 3 very small screws remove those and then you can remove the stuck cd
Why cantiopen my cd dvd tray from my keyboard ?
can you still open your cd dvd tray manually, if your answer is yes, then this would be a software issue, there would be times when part of software that controls the cd dvd device has been corrupted, so you may need to re install software to fix issue. If you cannot open tray manually, you may need to replace the cd dvd tray.
Why not open cd&dvd?
By opening what do you mean? Is it Tray or File? If Tray is not opening, Turn your Computer off, then insert a needle or a pin in the hole just beneath Tray and push the needle in slowly, after a few attempts, your Tray will open. But don't force, if you don't find yourself comfortable doing so, better call authorized service professional.
If it's about not opening Folder or File, there may be several reasons like dirty surface of CD/DVD, Corrupt File(s), Improperly created Sessions on CD/DVD etc etc. If this is the case, you may first try to clear the Surface of your CD or DVD with a soft cloth, slowly. If files or folders are not proper on your CD or DVD, or if you have incomplete writing sessions on your CD or DVD, you can not do anything to open them. Just create another CD or DVD. But if your CD or DVD is rewrite capable, you can format your CD or DVD and rewrite the data, but in this case your Data that's on your CD or DVD will vanish away.
If these things are tough,l please contact Authorized Service Center or your Computer Dealer.
How to get a dvd tray unstuck
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Cd tray wont open
CD/DVD Drive Tray problems
1helpful
DX4300-150
3helpful
Dell cd drive door won't open
2helpful
Hp pavilion a705w. no peripheral response
The fact is *********** board is very likely the matter. See all devices that do not need the motherboard to respond are all working (cd/dvd tray opens and closes, fans are on etc). On the other hand all devices that need the motherboard to respond are not working (keyboard, optical mouse, etc). It is more or less conclusive.
3answers
I have an Acer Aspire 5670 Note book Computer
There is a small hole on the face of the tray which is used to open the tray in this kind of situation. Use some needle and push into the hole. If the tray does not come out, you have to open the laptop and remove the tray.
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
How to instal a laptop dvd rw
open cd rom tray.open laptop lcd screen flat, remove the 2 screens on the back of the hinges.carefully remove the bezel(just above the keyboard, with the power buttons etc )from right to left.remove 2 screws securing keyboard.you will see one screw that holds the cd/dvd rom in place.remove screw,pul on tray carefully, cd rom will slide out. replace with new cd rom.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
