SOURCE: peg perego gator wont work in forward but works in reverse
I would replace the high low switch for this peg perego gator.
The high low switch as seen here http://www.shopjandl.com/mepu0002.html will not allow it to go forward. The reverse switch will sometimes not work at all as well.
You can contact http://www.shopjandl.com/. They repair them and know how to figure out what is wrong.
I would also check the wiring on the motors. Sometimes the wiring comes loose and doesn't allow all the speeds to function properly.
hope this helps
SOURCE: My Grandson JD Gator 4x2 toy won't go in reverse
it sounds like you need the peg perego gearbox, my kids noticed the locking and grinding noise so I contacted the guys at
http://www.mypegperegoparts.com/
and they walked me through the repair, they were very helpful
hope this helps
SOURCE: Gator doesn't go
I had a green gator model and replaced the switches in the shifter and that fixed the problem. I found them at
http://www.mypegperegoparts.com/switches.html
I also have called them before at 1.801.655.0800 for other help on these toys and they were very helpful
SOURCE: Gator 6x4 tranny problem
try posting the question in the forum for john deere gator and not the forum for the kids john deere gator
slow down your idleing enough for the shifting doesnt grind
