SOURCE: Whirring noise in the front-end of a 2000 Cirrus
it does sound like wheel bearing a cv joint dont make noise and then stop but you can jack the car up and in neutral try to shake the tire from side to side.to see if you have any play then turn the wheel by hand try to feel for roughness in bearing. let me know what you find. Phil.
SOURCE: 2004 jeep grand cherokee idling problem. Revs motor 200 to 500 rpms higher while driving.
I had the exact same problem on my 04 GC. I put some Techron Concentrate Plus Fuel System Cleaner in from Wal-Mart and it seemed to fix the problems right away. Let me know.
SOURCE: The engine rpm's increase when the engine gets warm.
spray a samll amount of either near each vacum line connection if the rpms go up theres your leak!!
SOURCE: Constant high pitched whining noise. Increases
you could be low on transmission fluid check that and make sure it registering properly on the dipstick.
