I had one of these and it turned out to be the headphone jack, when you put the headphone plug into the jack it disables the speaker and when you unplug the headphones it enables the speaker. There's a contact in the jack and it is probably stuck to headphones. The jack may need to be replaced. Try and wiggle the plug a few times but not hard as it may break from the curcuit board.
SOURCE: Exchange VCR to DVD Player
as far as the wiring yes its easy but the mounting is up to you to figure out.
SOURCE: 2002 Chrysler Town and Country
Ok, i'm assuming your replacing them, there is an oval rubber stopper on the backside of the rotor, in the backing plate, located near the bottom. it will tighten or loosen the e-brake shoes inside the rotor, loosen them all the way off, then get a big hammer and give them a really good smack, be carefull not to damage the wheel studs, if your reusing them hit on the hat of the rotor, if replacing you can hit right on the rotor face.
Use some antiseize on the hub before installin your new rotors, and don't forget to readjust your
e-brake and reinstall the rubber plug
SOURCE: chrysler town and country wiring diagram
2002 Chrysler Town and Country Car Stereo
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Strap or Chassis
Car Radio Illumination Wire: Orange/Tan
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Gray/Green
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Brown
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
SOURCE: Just bought 2005 Chrysler Town and Country and no
Naturally you could get them from Chrysler parts, if you want to save, go to radio shack and let the associate there check out the jack and he can come up with an inexpensive solution.
Just found this and it worked! Hope it does for you as well:
There should be a button on the DVD remote control with a headphone symbol on it. Make sure the headphones are turned on(red indicator on earpiece) and push the headphone button on remote. The headphones will only work in the back seats of the vehicle. Once you have audio to the headphones, you should be able to hit the AM/FM button on the radio and listen to the radio while back passengers use the headphones for video.
