Question about Kodak EasyShare V1003 Digital Camera
Flashing colours on screen
Various colours flashing on screen and showing on review after taking photo.
Posted by Robin Rennie on
Jim Jordan
    Master:
  • Kodak Master
  • 442 Answers
You have the review feature active and the flashing colors are most likely showing you the highlights and shadows that are too bright or too dark for a good photo. Look for the features in the menu to turn them off or try a factory default reset from the camera menu.
Posted on Jan 05, 2015
4 Related Answers
Anonymous
  • 126 Answers
SOURCE: Kodak Easyshare DX7630 screen is black and won't take anymore pic
your image sensor is bad it will have to be replaced by a camera technician .
Posted on Jun 03, 2009
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: can not take a photo
It's nearly impossible to troubleshoot your camera without seeing it, but your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Oct 21, 2009
Anonymous
  • 262 Answers
SOURCE: The view screen looks normal while taking a photo,
for that cased if the picture is washout or melted pictures it means camera defective., please call to kodak and have it repair toll free 1 800 235 6325 for U.S and canada only., If outside U.S may visit kodak.com and just click on contuct Us, and just select your country for the for the telephone number of Repair center
Posted on Nov 04, 2009
duane_wong
Duane Wong
  • 6826 Answers
SOURCE: when taking a photo the
The lcd screen is not connected or is bad.
http://www.kodak.com/global/en/service/products/ekn006609.jhtml?pq-path=683
The above is a web page that describes your dc4800 camera.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
The above is the final page of troubleshooting for the lcd screen which directs the user to get warranty service or out of warranty charged service.
Posted on Aug 06, 2010
When I take a photo the display screen flashes
This is a normal phoneme. The camera wants to show you where the picture is overblown. In these parts you can't see any details, because in JPG it will show it one colour. Most of the time this will be complete white.
When you are shooting in RAW (NEF in your Nikon) most of the time you still get detail, when you work in one of the RAW editors, like Photoshop, DxO and other picture edtors.
Dec 02, 2013 | Nikon D60 Digital Camera
All lights flashing on the printer
1. Go to Devices and Printers
2. Right click your printer icon
3. Select printing preferences
4. Click maintenance tab
5. Click Epson Status Monitor
If the show service required then your printer counter needs to be reset. Go to nearby Epson service center and have them reset your printer counter.
Nov 30, 2013 | Epson Expression XP- 202 Inkjet...
Problem with over-exposed photos
My suggestion is to try to reset to factory settings.
You may have accidently affected an exposure timing setting.
Or just try to use it in an automatic mode.
I sounds like a setting, since indoor flash pics are good, as you say.
Oct 20, 2011 | Samsung Digimax S500 Digital Camera
My nokia 5130 comes to white colour screen
1 .first download phoneix service
2 .open it
3. In Phoenix, click File>Manage Connections.
4. Now click New.
5. Now select the type of cable you are using. If you are using DKE-
2, CA-53 [N-Series] cable, select USB.
6. Click Next. It will find your product and say FOUND. If it doesn't
find any, you can try changing your cable type by clicking Back.
7. Click Next and then Finish.
8. Now your cable type [USB] appears in the connection list. Select
it. Click APPLY and then CLOSE.
9. Now select File>Open Product.
10. A list of RM code will open. Select your phone's RM code. Like
RM-133 for Nokia N73. Click OK
11. Now select File>Scan Product.
12. Your phone's firmware info will appear at the extreme bottom of
the Phoenix window.
13. Now go to Flashing>Firmware Update.
14. A window will open.
15. On that window click Browse button [the one with three dots].
16. A window will open with various products and various regions.
Choose the region or country of your choice according to the
language pack you want to install.
17. Click Ok.
18. Click Refurbish.
19. Now your actual flashing has started. Don't touch your phone or press any button until the flashing has finished. Also don't touch your data cable and your computer system.
20. At the end Phoenix will tell you to remove your phone as the
21. Now wait for your phone to reboot into latest firmware.
22. The flashing procedure takes 8-9 minutes, a lot faster than Nokia
Software Updater.
Flashing dead phones [Which show only white screen on startup]
Note: You can install any firmware in dead phones whether it is latest and
or the old one.
1. The procedure is the same for flashing Dead phones.
2. Start Phoenix. Connect your phone with USB Cable [phone is off
at this time].
3. Click File>Open Product. Select your RM code from the window
that appears. Click OK.
4. Click File> Manage Connections. Select No Connection. Then
APPLY and CLOSE.
5. Now straight away click Flashing>Firmware Update.
6. A window will open. Click on Browse button [the one with 3 dots].
7. A window will open with various products and various regions.
8. Check the option "Dead Phone USB Flashing".
9. Click Refurbish.
10. Flashing has started.
11. After some seconds flashing will pause asking you to turn your
phone ON.
12. Press POWER button of your phone until backlight comes up.
13. Flashing will proceed.
14. Your phone will automatically start when the flashing finishes.
After finish you can safely remove your data cable from h
Jan 09, 2011 | Nokia 5130 Cellular Phone
We would like to know how to use the timer
My Sony digital camera 8.5 mf not taking the picture. When open the flash door. it shows blank screen. While trying to take photo it flashing light is working fine but no photo absorbed image.
Any know how to resolve this issue.
Dec 17, 2008 | Polaroid i735 Digital Camera
Camera is flashing black and colours
Please remove the batteries from the camera and wait 20 minutes if possible set to factory setting .
Jul 04, 2008 | Fuji FinePix S5000 Digital Camera
FinePix A340....Flashing lines across LCD screen
I have the exact same problem !!! I wish someone would be able to help with this one !
Mar 25, 2008 | Fuji FinePix A340 Digital Camera
Trouble printing to photo paper
The paper you print on is not relevant. What happens is the green tint is the actual printer delivering all the colours to give a 'composite' black. On shiny photo paper this is emphasized where as on plain paper the colour is absorbed and shows as intended. So what can you do? Move away from black and go for a tint such as sepia.
Jul 03, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Kodak EasyShare V1003 Digital Camera Logo
87 people viewed this question
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
