Question about Refrigerators
I need a replacement crisper cover for avanti ff8wr refrigerator
Per http://www.avantiproducts.com/parts/ff8_ff12y_breakdown2.pdf, it's part number 3011424800 or 3011436201. Avanti no longer manufactures these parts. I'm hoping that I can find second hand.
Anonymous
  • 93 Answers
SOURCE: Avanti EWC16B (wine cooler) got fried by power surge
A lot of time during storms the control boards in appliances get messed up. Try unplugging it and plugging it back in after about 20 seconds. A lot of times that will reset the controls.....if they did not get fried.
Posted on Sep 12, 2009
Testimonial: "I enjoyed the detailed explanation. The fuse was indeed blown, but the diode probably as well. But can anything else be blown??"
I need a 12V water pump for the Avanti ice maker PIM25SS
Hello there,
You can get the 12v water pump for the avanti ice maker from the link below:
http://www.avantiproducts.com/contact
http://www.nextag.com/ice-maker-pump/products-html
Hope you found the part you are looking for in the links.
Hope this helped. Goodluck Elect_Comp
Sep 05, 2011 | Avanti PIM25SS
Not cooling at all.
If it is worth it you should have a refrigiration tech look at it.
It could be out of Freon, or the compressor may not be operating.
Mar 21, 2011 | Avanti EC15W-2 Compact Refrigerator
Hi, i'm looking for a new 'veggie crisper box top shelf' about 13x17, and a 'bottom shelf' for the fridge door, Avanto Fridge Model# FF8SSR/FF8WR Cheers, Christian Lawson 6467846628
IF you go to Appliance Parts Depot and just put your brand along with your model number in the spaces provided then you should be able to order the parts you need your self. That away you can have them shipped to your house and not have to pay all the services fees that companies try to charge you for when they are going to do the same thing. Hope what info that i have gave to you is useful. If not you can email me at [email protected]
Jan 19, 2011 | Avanti FF8SSR Top Freezer Refrigerator
Temperature began to warm up daily until now it just stopped cooling
Hi, I tried to cross the model number you gave with Avanti and it did not do an exact cross reference.
Usually when a cooler slowly warms up the causes can be
1. The Compressor is not running at full speed or has stopped running
2. The PTC start / run relay / Klixon assy mounted on the Compressor has failed
3. The run capacitor has failed.
4. The temperature control has failed.
If the compressor is running and it is NOT cooling then there is a coolant leak or the coolant system had become blocked usually in the capillary tube area.
The current model numbers for parts are here:
http://www.avantiproducts.com/parts-accessories/current/yes
And the Discontinued model parts are here:
Just note there are many aftermarket (like part) sources that will be much cheaper than Avanti sourced replacement parts. Most repair techs would advise you to use locally sourced replacement parts.
Feb 04, 2010 | Avanti WC42 Wine Cooler
My Avanti frig has the model# of FF8SSR/FF8WR but
We have parts for Avanti refrigerators. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the information on your parts.
We look forward to working with you.
Nov 09, 2009 | Avanti FF1101W Top Freezer Refrigerator
Sep 12, 2009 | Refrigerators
Avanti DG 241 BS gas range oven burner goes out and wwill not rel
You need to order parts from AVANTI.
Very disappointing customer service.
I have been waiting 6 weeks for a new thermostat. It will not
arrive from China until June -- I was originally told it would come in April. All AVANTI parts are from China and AVANTI in Florida is the
only dealer. I will never buy AVANTI again.
Feb 19, 2009 | Avanti DER24CSS-1 Electric Kitchen Range
Have an avanti refrigerator model #FF82. and the door to the chiller room, which is under the freezer, needs to be replaced. How do I go about replacing this door?
Hi, I have an Avanti refrigerator model FF82 and there are no shelves inside. Are there spare parts available. There is only a chiller room and 1 bin on the bottom. Thanks
Apr 26, 2008 | Refrigerators
Lint filter broke
On page 20 of your user manual is the number for ordering replacement parts:  800-220-55
Here is their website also:
http://www.avantiproducts.com/index.php?page=contact
Oct 11, 2007 | Avanti W798SS Stainless Steel
Refrigerators Logo
176 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
