I cannot reopen goggle chrome unless I reboot my computer. When I close goggle chrome I get a pop-up that reads, your profile could not be opened correctly. I have looked at my profile and can't find anything wrong. I have been using goggle chrome for quite some time with no problems. I am lost
SOURCE: my computer is rebooting over
The first thing you should look for is a virus, some of them can have that affect on your system. The fact that you can start you computer in safe mode means that the likelyhood of this being a hardware problem is very low.
If you dont have any antivirus program loaded, then try AVG, it's free. just google AVG to find a download.
Next, try the following: go to the start button, click on the run button and then typr msconfig in the run line. In the window that pops up, select the staartup tab and uncheck all of the checkboxes on the left side. Then click ok and reboot you computer again. If your computer stats up without any further problems, then you have your cuplrit. just unselect one item after each reboot and use your computer for a while until it is long past the time you would normally have the reboot problem. Then, do it over and over again until your computer starts rebooting again. once it does, turn that program off and uninstall it. IF it's something you really need, install it again.
SOURCE: sage has error and closes
In your sage data directory there is a file queue.dta delete this and you will be able to log back in. I would recommend you upgrade to Instant V14 though if you are using Vista. V8 came out in 2002/03 not designed for Vista
SOURCE: drawers wont open or close.
I will assume you are talking about the CD/DVD drive drawer.
Get a large paper clip. unbend it part way and use the straight end to push the drawer out using the little hole located on the front of your drive.
You may have a stuck disk in the drive.
SOURCE: Dives on Dimension 8250 will not read without first using "eject"
First thing I would try is to go into windows device manager and uninstall both drives. Now turn off the PC and reboot it. Let Windows plug and play find and reinstall the drives. If it cannot find drivers, and you don't have the driver disks, tell it to look in c:\windows\system or c:\windows\system32, your current driver sould be in those folders. Gordon, if this doesn't do the trick, let me know and we'll move on to other possibles; but this should fix this problem about 80% on the time.
SOURCE: dell dimension 2400 cd drawer opens up when
The latch which holds the CD tray in place once the drawer retracts must be faulty. You will need to take it to a repair shop in order to have it fixed, unless you are comfortable with pulling apart the computer shell in order to test the latch to see if it is functional.
If you are not a professional, I would suggest taking it to your local computer repair store for service. They will be able to assess if that is the issue you are having.
