After finished first washing, it shown 'Fb' and can't continue to wash next.
Hitachi SF-130LJ User Manual
http://www.hitachi-th.com/hitachi_new/Download/SF-130LJ.pdf
Testimonial: "User Manual don't have error code 'Fb'"
SOURCE: Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
SOURCE: Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
SOURCE: LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
SOURCE: washing machine blinking f-24 error code.
"F24" is a Water Temperature Sensor error or Heating Circuit failure. The first step to troubleshooting these washers is to unplug the unit for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes the error codes can be erroneous and a simple reset of the CCU will correct the problem. If the error code reappears following a CCU reset, you have a genuine problem.
If the error code comes back, check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Check to make sure the connector is still plugged in. The connector can become loose or unplugged due to vibration. If the connector appears to be okay, unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
I hope you find this information helpful. If you have further questions, please let me know.
SOURCE: Washing machine displays an LF error code.
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged
the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Testimonial: "We followed your suggestion and disconnected the hoses and they had "gunk" in them. We flushed them out, reconnected and everything seems to be fine."
"Fb" is supposed to mean "F6" 2since it uses a '7 segment disla iThe manual says F0 - F10 are
"Fb" is supposed to mean "F6" since it uses a '7 segment display' .... It says in the 'small print' of the page on error codes that F0 - F10 are e
"Fb" is supposed to mean "F6" since it uses a '7 segment display' .... It says in the 'small print' of the page on error codes that F0 - F10 are serious faults that require professional attention...
Chris Hall Posted here on Jun 23, 2011: The code is actually F6 (not Fb - Easy mistake). depending on the model of the machine, my lookup tables show that it is either: A fault with the heater element (Usually this means the heater element is corroded and now shorting out to earth). Replace the heater element. or The door interlock switch is faulty. This is the switch that locks the door so you cannot open it when it is full of water
