SOURCE: How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
SOURCE: Flashing red status light on NEC VT45 projector
make sure the doors are shut all the way! there is a little button there.
SOURCE: how to reset a nec lt245 projector timer
There are buttons on top of the projector that correspond to the needed buttons on the remote. Follow the directions in the manual using those buttons rather than using the remote.
- Press the Menu button
- Arrow all the way to the right on the menu and stop on Resets
- Press the enter button and select the reset option desired and press the enter button and confirm your choice.
SOURCE: Steady red status light on NEC VT45 projector.
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try www.projectordoctor.com
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
