Question about Jazz Dv140 5mp Digital Camcorder Color Lcd Screen Youtube Ready
I read instructions for the jazz dv140 and i opened the lock on the sd card and inserted into the camera. I clicked yes to format. In the screen it says waiting i have waited for over 3 hours and burn
My email address is [email protected] if you want to email me.
Karl Whisenand
    Genius:
  • 1,554 Answers
Max size of card supported is 8 gb for that camera
Posted on Oct 19, 2014
  • Betty Brown
    Betty Brown Oct 19, 2014
    i just bought the dv140 camera and sd 8gb card so it should be empty i never used it. it was still in the original package so was the camera
5 Related Answers
Anonymous
SOURCE: Nothng is working.
Nevermind I used a different SD card and it worked
Posted on May 24, 2009
Anonymous
SOURCE: Jazz HDV178 - won't focus
jazz hdv178 won't focus
Posted on Mar 03, 2010
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: I purchased a JAZZ 150
The issue may be from some kinda incompatibility with the operation system or a virus from the computer ...Try to reset the camera by using the reset button if it has one ..or removing all power source from it ..(batteries or ac adapter ) ..
restart it and see if it gets back ..
in the future try to use a a card reader and get the files from the sd card directly in the computer ..
There is a possibility that you need to select from the camera screen the type of connection on usb ...cause it may have 2 of them ..like charging from usb ..and pc connection for download...
Posted on Aug 16, 2010
Anonymous
  • 19 Answers
SOURCE: I have a jazz DVX50.
It is possible the card as become corrupted a common problem with cheaper SD cards.
2 Soulutions
1 Try reformatting the card in your pc by following the directions on the website below
http://www.ehow.com/how_4793481_reformat-sd-card.html
2 Unfortunately you may need a new card
Posted on Apr 08, 2011
Anonymous
  • 35 Answers
SOURCE: When I turn on my Jazz DV 152/ T20 it displays
Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.
SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
Posted on Oct 01, 2011
I got a jazz hdv140 cam corder how do I format the sd card
Here is a link to the user manual. Please look this up in that manual. Jazz DV140 User Manual
I read instructions for the jazz DV140 and
Format should take only a few seconds. Confirm if the card has a "protect" switch, and it's turned so you can access the card.
Oct 13, 2014 • Cameras
Jazz dvx40 power-on/off problem
Yes. Take the batteries out to make it go off. You did not add the SD card yet, did you. The SD card are tricky also if it comes with an adapter you have to insert the SD card adapter into the bottom of the SD card and insert it into the Jazz to get it to work properly. Instructions are available online with Google search. These are so tiny you won't think it will go in there but it clicks in perfectly when you find the right edge. And, check the lock on the SD card to unlock instructions for this are also in a Google search. If all else fails get a replacement. It should work if you do all of these things (even on Ubuntu0.
Tried formatting sd card on jazz dv140 but its stuck on waiting, why?
Mine did the same thing. Come to find out I had the wrong SD card. What walmart sold me was an SD Adapter card. So make sure you have the right type of SD card.
What kind of sd card goes into my jazz DV140 camera
SD cards should be available at just about any department, electronics, or office-supply store. The brand doesn't matter, though I'd stick with the major brands. Make sure you get an SD card and not an SDHC card.
SD card can't be read "Card Locked" is all that
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
1helpful
2answers
I cant format my 8 gig sd card in jazz z40 camcorder. it says no card
if u read your instruction manual it says it only supports up to 4 gb
This camera reads "card error" and won't format a
yes. you can try to insert the sd card to a computer using any all-in-1 memory card reader. then if windows detects it, right click the card's drive in windows explorer then select format. choose FAT as file system type. before you put it back to your camera clean the card's contact points, insert the card and if the camera detects the card format it again using the camera's format tool.
2helpful
2answers
When I turn on my Jazz DV 152/ T20 it displays "Read card..." and then nothing happens...I have a 4GB SDHC card by SanDisk...both camera and card are new....is this a faulty camera or am I doing something...
Jazz Dv140 5mp Digital Camcorder Color Lcd Screen Youtube Ready Logo
Top Jazz Video Cameras Experts
Ekse
Jesse Walters
Jesse Walters
ray gallant
Are you a Jazz Video Camera Expert? Answer questions, earn points and help others
