<!-- from fixya rte -->What is a alpha charactor - ST-Lab PC Laptop Mac Computor to HDMI TV Presentation Converter VGA and Analog audio To HDTV Converter Ad
Calculator does not have a solve program, but you can use it to solve the quadratic equation with a little effort. If you know the theory skip toward the end. Here is the example:
Let aX^2+bX+C=0 1. First calculate the discriminant usually called Delta and given by Delta =b^2 -4*a*c store the value in the variable D If Delta is positive you have two roots X1 and X2 given by X1=(-b+square root of Delta)/(2*a) X2=(-b- square root of Delta)/(2*a)
If Delta is equal to 0, X1=X2=-b/(2*a) If Delta i negative, no real solutions exist
You only solve if Delta is positive or equal to 0.
Putting in the values of a, b, and c value of a (put you number) [SHIFT][STO] A value of b (put your value) [SHIFT][STO] B value of c (put you value) [SHIF][STO] C
[ALPHA] B [X^2] -4[x][ALPHA] A [x][ALPHA] C [=] Value of delta is displayed. If it is positive, you store its square root in D
[Square root] [ANS] [SHIFT][STO] D ;
Calculate 1/(2*a) and store in variable F 1./(2[x] ALPHA A) [SHIFT][STO] F
To obtain X1 [ALPHA] F [x] ( (-) ALPHA B + ALPHA D ) [=] To obtain X2 [ALPHA] F [x] ( (-) ALPHA B - ALPHA D ) [=]
Be careful: the (-) is the change sign not the regular minus sign.
The Alpha MUST tie to a computer to do the recording. Audio lines COULD go from the keyboard to the inputs of the Alpha to the Alpha to be recorded on the computer.
Now press desire function key. Here in this case, Press "Y="
Many keys in this calculator serves one than one function which can be access through by pressing either "2nd"(Blue Key) or "ALPHA"(GREEN KEY). Such extra functions are noted on keys in Green or Blue color. These additional functions are accessed by first pressing corresponding color key and desired function Key.
For example: pressing UP and DOWN keys navigates the screen up and down if we press ALPHA key and then UP/DOWNkey, it will scroll screen UP/DOWN by a page. Also you can use this combination for copy functions. if we press 2nd Key instead of ALPHA, we can change Contrast of The screen
You have a way to enter the Variables A, B,C,D, Y and X. Use the ALPHA key For A use ALPHA change sign key (-), below the Fraction Template. For B use ALPHA (degree ' ") For C use ALPHA (HYP) For D use ALPHA (SIN) For X use ALPHA right ) For Y use , ALPHA (S-D) key For =, use ALPHA and the key below the SHIFT key. May be marked CALC. The = is in the same color as the ALPHA on calculator. It should be to the upper right side of a key.
(I have an FX-991ES that is compatible with the FX-300ES, but since I do not have a picture of the FX-300ES calculator I cannot be more specific than I have been, lest I mislead you.)
It means printer error. Usually after a paper jam. Clear any paper out and try turning off and on at the wall.
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
royal 110cx User
royal 115cx User
royal 130cx User
royal 425cx User
royal 435dx User
royal Alpha-580 User Programming
royal Alpha-583cx User Programming
royal Alpha-600 User Programming
royal Alpha-600sc User Programming
royal Alpha-601 User Programming
royal Alpha-710ml User Programming
royal Alpha-9155sc User Programming
royal Alpha-9180sc User Programming
royal TS4240 User Programming
I checked your problems. There are three questions asked by you. The first one concerns how to insert the = sign to create an algebraic equation. It was answered correctly by someone.
The second one also concerning the = is still awaiting a solution. But it was filed under Copiers.
The third question (this very one) is no question at all since you claim the site is sending you in circles.
Here is the solution to your two questions. To insert an equal sign in an equation on the Casio FX-115ES one uses the key combination [ALPHA][CALC] (=).
To insert other variables (A,B,C,D,X,Y) you do as follows
The only other uses of the [ALPHA] key are [ALPHA][Integral] (:) [ALPHA][M+] (M) to access constant memory register [ALPHA][x10^x] (e) to access value of the base of the natural logarithm.
Hello, The calculator does not have a solve program, but you can still use it to solve the quadratic equation with a little effort. If you know the therory skip toward the end.
Assuming this is an apple product, check how many chactors in password, and in the description of the wpa or wap if it says hex or hexadecimal then one common problem is the standard is 13 charactors if yours is less the software fills (and the router assumes) 13 so autofills the rest, differebt manufactrors use different fill in charactors so it seems wrong. My workaround was to add As up to 13 at both ends and it worked.
