2002 Dodge Grand Caravan Logo
A
Anonymous Posted on Oct 19, 2014
2002 Dodge grand caravan rear hatch lifts then drops instantly
Rear hatch drops suddenly when in up position
laspeyrer
Level 2:
  • Expert 128 Answers
  • Posted on Oct 19, 2014
laspeyrer
Expert
Level 2:
Answers
128
Questions
Helped
85648
Points
218
Problem seems to be the struts that hold the door up(shocks) need replacing.You may want to check with a body shop before you spend any money. Just to make sure.
A
Anonymous
Change the lift struts
5 Related Answers
Anonymous
  • 141 Answers
  • Posted on Feb 08, 2009
SOURCE: 2000 dodge grand caravan rear heater core tubes need replacing
a lot of pain and heart ache. even on a rack they are a pain . check with your dealer there wae a recall on them for failing its worth the phone call to see kdc744
Anonymous
  • 76 Answers
  • Posted on Mar 15, 2009
SOURCE: 2002 dodge grand caravan rear hatch latch
ok, then the lock actuator is most likely seized, if you need instructions to repair, let me know, you have to get the part first, this will be a dealer item most likely. Then it's pretty simple. Remove the interior panel on the liftgate, you will see the latch and lock assembly, and a rod coming from it,the rod leads to the actuator. remove the rod, the retaining screws for the actuator, the electrical connector and then reverse for installation. Any issues let me know.
Good luck.
R
Anonymous
  • 1392 Answers
  • Posted on May 28, 2009
SOURCE: Rear wiper motor not working
Remove the wiper arm. Lift the hatch up. Remove all related trim around the hatch. Unbolt the wiper motor, and install in reverse order.
Anonymous
  • 6 Answers
  • Posted on Jun 25, 2009
SOURCE: 1996 grand caravan rear hatch won't open. bought
pull all the plastic panel ad the inside and ty to open manualy from inside.
dnewcombe1
Dana Newcombe
  • 1564 Answers
  • Posted on Aug 29, 2009
SOURCE: 2002 Dodge Grand Caravan - Power Liftgate Stuck Open
Check all the fuses under the hood and under the dash. Then try having someone wiggle the liftgate while you "tap" the down button repeatedly. Do not apply too much force to the liftgate.
Removal of rear door lift hatch interior plastic panel on a 2005 Dodge Grand Caravan to push out dent in metal door from the inside.
The rear door panel is secured to the door using screws and clips. The screws will be in the handle used to close the door and there may be plastic plugs in the handle hiding the screws. Once these screws are removed, the handle will come off. Look for any more screws along the panel. If there are more, they will be visible. Once the screws are removed, pull on the panel to release the clips that secure it to the door. These clips will require some force to release them and will make a snap/pop sound once released. You may have to put a screwdriver/wedge between the panel and door to start the process of releasing the clips
How do I Remove plastic interior door panel from lift hatch
there is some screws I think 6 star screws and plastic anchors on the side just pry with a screw driver gentiles so you do not brake them will brake if cold good luck
How to remove a interior plastic door panel from a 2005 Dodge Grand Caravan lift hatch
2 screws in arm rest 1 on the both side 3 on the bottom 1 in the door handle lift up if power windows watch for wires
Gate open. Why won't limit switch turn off?
dodge caravan stuck liftgate or hard to open DIY fix - YouTube
? 3:21
https://www.youtube.com/watch?v=0QqnMw5ZXTk
Nov 13, 2011 - Uploaded by banshee8989
Lift gate support strut replacment on dodge caravan. ... Chrysler Dodge Stuck or Hard to Open Liftgate DIY replacement - Duration: 6:46. by Ilm ... 2006 Dodge Grand Caravan easy inner ball joint replacement - Duration: 12:52.
Rear Lift Gate Support Attaching Bolts May Break : Dodge ...
repairpal.com > Problems > Dodge > Grand Caravan
Rear Lift Gate Does Not Stay Up on Dodge Grand Caravan. The rear lift gate ...support bolts have broken off I use apiece of pipe to hold the gate open. Upvote.
Where is the gate sensor for a 2008 Dodge Caravan? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 30, 2012 - The "gate" light stays on on my dash and the over head lights stay on ... you roll the interior dimmer all the way down) in my 2008 Dodge Caravan. ... Clicking noise in 2008 Dodge Grand Caravan? ... Are the 2010s any better?
I have a 2009 Dodge Grand Caravan. As you drive along a chime starts going off. No lights on dashboard light up.
Be sure all doors are closed securely including rear hatch. If that still happens one of the door or rear hatch electrical switches may need to be adjusted. If the car has been struck lately, start looking in that area.
2helpful
How do I change rear turn signal bulb on 02 Grand Caravan?
open the rear hatch,there are two screws holding each taillight assembly in,remove the two screws for the side you want off,pull out on side of lens assembly where the screws were,un hook the outer side when you swing it out,
1helpful
Good luck.
R
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
