Question about Garment Steamers & Presses
How to fix permanent beeping in salter steamer
Shark Super Steamer
The steam generator is defective.
Aug 28, 2016 | Euro-Pro Shark Super Steamer
My steamer is no longer producing steam, how do I fix?
To troubleshoot something like this.
1. make sure it's plugged and the outlet is working.
2. Is it getting hot? If not, either the heating element is burned out or not getting power.
3. If it is getting hot check the steam ports for calcium build up (run straight vinegar through it)
Jul 14, 2014 | Garment Steamers & Presses
Home touch garment steamer model ps-280 wont turn on
If it were left on its possible that the element that heats the water has burned out think blown light bulb have your Mr Test it with a ohm meter to see if the circuit is open
May 02, 2014 | Garment Steamers & Presses
My hand held little steamer will not get hot. switch comes on, but that is all it does
If the switch isworking then the only possible fact is that the heating element has failed and it might be too costly for a change.
Jun 10, 2013 | Ingenious Designs, Llc My Little Steamer...
Home touch ps-250B steamer
Need Water Tank top cap which is brocken
Apr 21, 2013 | Homedics Garmet Steamer PS-250B
What are the advantages of using a steamer over an iron?
steamers are usually believed to be easier to use and less damaging to the fabric over time
Jan 30, 2013 | Garment Steamers & Presses
Garment Steamers & Presses Logo
744 people viewed this question
Top Garment Steamers & Presses Experts
ray gallant
Bill Boyd
Tom Chichester
Are you a Garment Steamer and Press Expert? Answer questions, earn points and help others
