SOURCE: machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
SOURCE: Straight sewing but only a few stitches before stopping
Hi Gaden....It's obvious by your post that you have advanced knowledge in sewing/machines including maintenance, so I feel very confident that your issue can be resolved by updating your software. Please click on the URL below, and download the approriate updates that correspond with your equipment.......Please update your post so I'm aware of your status....good luck my friend http://futura-support.com/downloads/patch.htm
SOURCE: machine will not stitch
It is either a top or bottom tension problem. Top tension speaks for itself. Most folks do not know that there is the facility on the bobbin case to alter the bottom tension. Your user manual will tell you how to do this. It is very difficult to describe how to do it you need diagrams or to be shown
SOURCE: My Futura CE-150 beeps and stops sewing after only a few stitches
Look for the buttonhole lever, just in front of the presserlever, on the lefthand side of the machine. Pull it down and push it back to the top. Good Luck
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
