Question about Alcatel OneTouch Fierce for MetroPCS Cell Phone
Hoe do I Remove the non-removable battery
Can't make or receive calls or texts
Cecilia Rose Lance
    New Friend:
Urm... it's a NOn-REMOVaBLE battery. Work it out
Posted on Feb 15, 2015
KIKKY
    New Friend:
YOU DON
Posted on Nov 21, 2014
Cant make/recieve calls/texts with 2 weeks service left!
you have activated call abort
try to restore it with factory settting but before doing so backup your data and remove your memory card
Jan 26, 2014 | Straight Talk LG Optimus Zip Cell Phone
Tip
Phone Cannot Send or Receive Calls and Text Messages: A Simple Electronic Glitch
It is frustrating when only your phone cannot send text messages no matter how strong the network signal is. Sometimes you feel nobody cares about or remembers you because nobody calls or texts you but actually there are. Your phone just can't be reached or can't receive text messages. When these happen, turn off the phone; remove the battery and then the SIM card. Insert the SIM card to another phone and try sending text messages; if you still cannot send text messages, remove the SIM card and let it sit off the phone for at least fifteen minutes then insert it gain. You should be able to send text messages after that, but make sure you have credits.
The next thing you should look into is the phone. Make sure network signal is present then insert a known good SIM card in your phone and try sending text messages. Reset the phone if you still cannot send text messages, but back up important files and data, such as contacts, videos, images, and messages, before doing so.
One simple way to "reset" the phone is by removing the battery and letting it sit for at least fifteen minutes. Another way is by restoring the phone settings to factory settings. Simply navigate to settings then phone settings and select "restore to full factory settings" depending on the brand and model of the phone.
This tip is not intended to solve virus or firmware problems but rather to avoid unnecessary visit to the service center and save few bucks from a problem only caused by a simple electronic glitch. Check the network signal strength and your credits before jumping into any conclusion.
on Apr 06, 2010 | Cell Phones
Samsung GT-E1150i can't send text messages
I was told to remove the battery and SIM card, wait three minutes then power up the phone again. (Time and Date have to be reset) Unfortunately this did not solve the problem so it could be a Vodafone network problem. I am wary of trying the SIM in a different brand or model of phone in case of an unexpected reformat occurring, so until a duplicate phone arrives the job is on hold. In general one just cannot get the right staff these days. Take care!
Feb 11, 2012 | Cell Phones
Cannot make a call msg comes up "connection error"
This is usually due to the phone being lock to a distant cell tower, if that is the case just shut the phone off and remove the battery wait about 2 minutes and replace the battery and restart the phone,if that doesn't fix the problem it may be an internal problem or a carrier problem.
Dec 01, 2010 | Nokia 6710 Navigator Cell Phone
Hoe to insert/reomeve sim card?...
The position of the SIM card holder depends on your phone model. It might be placed under the battery or on the side of the phone. Before inserting/removing your SIM card, turn off your phone and make sure no charger is connected to the phone. Insert your SIM card according to the illustration that you find close to the SIM card holder.
Note: Without a SIM card, you can't make or receive calls. In some countries you can make emergency calls without a SIM card.
May 20, 2010 | Sony Ericsson Walkman® W995 Cell Phone
I have a samsung propel and I am not receiving text messages I am I doing something wrong. I stopped receiving messages yesterday and yes people have sent me messages
first thing to try is a battery pull ..remove battery for 30 secs the power on the phone ...if that doesnt work call your carrier and make sure you have the correct message center number
Mar 17, 2010 | Samsung Propel Cell Phone
Can't send or receive text messages
The problem is not on the phone setting but on the sim card itself. Remove the battery and the sim and let it sit for 5 minutes. After that, insert sim and battery then try sending a text message.
To verify, insert your sim to another phone and use a different sim in your phone.
Sep 25, 2009 | Sony Ericsson K608i Cellular Phone
My sony ericsson phone says when i turn it on is (no network cove
I would first try removing the sim card and placing it back in the phone. Open the battery cover, remove the battery, remove the sim card, rub it with a clean cloth on the metallic areas, replace the sim card, replace the battery, replace the cover.
Turn phone back on.
If that doesnt fix it, where did you get the phone? If its through t-mobile or something, contact them. If you bought it online, try sonyericsson's website
May 06, 2009 | Sony Ericsson w580i Cellular Phone
Cannot send/receive texts or calls.
Two things to try. One is remove the battery then remove the sim card make sure it is clean. Wipe it with alcohol. If it still does not work you may need to go to your nearest store and they should be able to check it for you to make sure there are no updates that your phone normally downloads and you never know it. Usually when they place a new tower. I had a similar problem. Also if your sim chip is bad ATT can replace it usually at no charge and that should fix the problem.
Mar 24, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Cant call
These devices are made to work in both modes you may have to reset, remove the battery while the cell is on and count to 30, then replace battery and power back on this should work! If it does'nt call your provider and check Sim card.
Sep 11, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Alcatel OneTouch Fierce for MetroPCS Cell Phone Logo
57 people viewed this question
Top Alcatel Cell Phones Experts
Dakshinamurthy...
Ron Rak
Ron Rak
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
