Question about Tomtom One XL GPS Receiver
Tomtomsoftware lost lost software only on/off ok screen on time red cross showing
Posted by kamal on
GPS Service Djoslax
    New Friend:
  • 59 Answers
You need to install new navcore for your device,and after that instal maps.
Posted on Oct 18, 2014
When turn On can get the screen showing the GPS connected to Computer when not connected ,On Battery only, get red cross flashing
If your TomTom shows a red cross, it means the device is not able to load the software to be able to operate. Some devices have this software on a SD-card, some have it stored on an internal memory.
If there was a SD-card in your TomTom, I would suggest to put it back. If there is a empty SD-slot on your device, it could be you lost your SD-card, but some TomTom devices have an internal memory AND a SD-slot for memory extension, so if you have an empty cardslot it doesn't necessarily mean there has to be a card in it.
When you never saw a SD-card, probably some data went corrupt on the internal memory. When you have a SD-card, probably some data got corrupted on the SD-card.
To repair the software, you need to connect your GPS to your PC or Mac with a USB cable.
You also need the program TomTom HOME. You can download it for free on the TomTom website.
With TomTom HOME you can update the operating system of your device for free (map updates are nor free).
Try updating, and see if your device works again.
If this doesn't work, post it here.
May 14, 2015 | Tomtom GPS
Red and white cross appears on screen on satnav
cross indicates software problems or lack of software
Feb 17, 2013 | Tomtom GPS
I have a Tom Tom XL IQ Route/XL Classic which is 1 month old. When I switched it on it came up with a blue screen , picture of Tom Tom in left top corner and on the right a white cross flashing on a red...
the problem it has is the software seems to either have a problem or the mapping itself is the problem, if you bought the device brand new from a shop like halfords, then you will have the TomTom 1 year warranty, but you need your reciept for it to be authorised.
if you have done a back up of the device previously on tom tom home then you can format it and it may back up ok.
alternatively go into any Halfords or other store and speak to the specialists and they'll give you any info they can give.
Oct 04, 2012 | Tomtom Tom XL 325 330 330S 340 340S GPS
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
My ipod classic 80gb just comes up with a red cross on the screen when i turn it on, i have tried putting it into manual disc mode but nothing happen.
red cross? I have had unhappy faces on my ipod, but not a red cross. Hmmn, my best bet is that the software is corrupt. Try restoring the iPod and see if that works.
Feb 17, 2010 | Apple iPod classic MP3 Player
Mitsubishi wd 52525 lost greens and blues. only colors on screen are red hues.
This the classic symptom for component input wires being crossed. Check color coding on tv input and signal sourse. Green,Blue and Red wires must correspond. If ok Is the color off on the tv menu also. If so and wires are ok replace light engine.
Nov 03, 2009 | Televison & Video
TomTom GO 720 - flashing red circle with white cross on screen
Hi, I am back, just got the problem solved, I called their tech support at no charge (866-486-6866, Glen) , really good service.
First turn your firewall off (if you have one). You need to go into your 720 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 720 , bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 720 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button, when done, go back and to device (option in top of your screen) and select disconnect device, restart your 720 and it should be back to life with the upgraded software.
Hope this helps
Aldo
Nov 20, 2007 | Tomtom GO 700 GPS Receiver
Tomtom One XL GPS Receiver Logo
52 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
