How do I get my ps2 to show on screen
I have purchased a new cable with red, blue and green connectors to match tv, but with ps2 running, I cannot find a source to show gameplay.
Posted by Derek Telfer on
Mikey
    Top Expert:
  • Televison & ... Master
  • 6,720 Answers
Sounds like you have a composite AV cable - at TV end that would be 3 phono leads red/yellow/white. Set the TV audio visual to CMP for composite!
Posted on Oct 18, 2014
3 Related Answers
Anonymous
  • 61 Answers
SOURCE: black and white picture
Try going into player's menu, and set video out or TV type to NTSC.
It might have switched to PAL, or disc is PAL and player is set to any.
Posted on Dec 13, 2007
David Petry
  • 961 Answers
SOURCE: what cables go from my 55 inch hitachi tv to
I have never herd of a red and blue combo but, The three, red, blue, and green are "component" cables. Hopefully your DVD player has a red, blue, adn green component out, not to be confused with red composite out. Composite cables are yellow, red and white, and, your tv has componenet in. The component cable will give you the best video quality. When installing make sure they are inserted all the way but twisting and wiggling or you will have a bluish, grenish, etc. picture. The composite cables give you the video only, so you will have to provide the audio. Audio can be achived using composite red and white or digital optical.If you second monster cable is red and white you can probably use those To go from "audio" red and white out on DVD to audio in red and white on tv. You must use the same audio input that corresponds to you video input.
Posted on Apr 09, 2011
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: I just purchased a 37"
hi,
Do one thing connect the composite video and enter in to the setup menu of Toshiba DVD/DVR. Browse in the menu for the video output system format (color system). If you are in US then select the setting to NTSC. If there is no such setting in the DVDDVR then it is not compactable with the new tv.
OK
Posted on Sep 02, 2011
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
I have a PHILLIPS DV3 47 inch smart TV. But I cannot hook up to my dvd recorder
The blue/red/green aren't a component signal which is why they don't match and are causing the no signal message. The dvd recorder is most likely only giving out RGB which you need to plug into those RCA sockets or SCART/Peritel connector if you have that.
Sep 30, 2014 | Televison & Video
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
Blu Ray showing "split screen/double
Did you check your settings on your tv and blu ray?
Jun 04, 2017 | Televison & Video
No sound on tv and black & white
The red, blue, and green are the component cable hookups. What you have w/ red, white, and yellow is called composite or on most TV's (AV) See if the TV has a side port for like a camcorder, etc. It will not work by hooking into the red/blue/green as they are different signals.
It is possible that your yellow jack may be separate from the red/white audio left/right jacks.
May 04, 2010 | Sony PlayStation 2 (PS2) Console
Connect dvd recorder to cable box and hdtv
I have posted a tip that should help you out with your problem follow the link below but there is one minor variation for connecting to your TV.
On step 3 of the connections section substitute the follow for your situation.
You will need 1 component cable (Red/Blue/Green/Red/White cable)
3) Connect the Green/Blue/Red connectors to the back of the DVR labeled "COMPONENT OUT" matching the colors. Connect the same ends to the input of the back of the TV again matching the colors.
4) Connect the last two connectors (Red/White) to the back of the DVR to the AUDIO IN on the TV.
Other than this variation all shoud be the same.
CLICK HERE for complete tip.
Good Luck...
Jan 27, 2010 | Panasonic DMR-E55 DVD Recorder
After having my dish network upgraded to HD and installed, i notice on my tv now that the green and red colors are not there, predominant on channels like ESPN that use these colors most. I._E.: football...
Sounds like one of the cables got plugged in wrong.
Look at the back of the HD box and there should be a cable with 5 ends on it (Green,Blue,Red, White and Red).
Often times a flashlight can help make sure you see the colors clearly.
The Green,Blue and one of the Reds is for video. The White and other red are for Audio.
When you unplug the connector the connection it is attached to is also colored. Check to make sure the colors on the cord match the color they are connected to at the box.
The most common mistakes connecting these cables are:
1) Crossing the Green and the Blue cables.
2) Connecting the Red Audio cable to the Red Video connection.
If all of the connections match the correct colors find the same cable where it plugs into the back of the TV and check these connections that they are correct.
When you find and move the cable to the correct connection this should clear up your color and you can begin to enjoy your new toys....
Good Luck....
Jan 15, 2010 | Panasonic CT-34WX54 34" TV
Hook up of dvd to tv
hey I think you need to use component cables blue green red from the player to the tv, make sure the blue green red ports are also on the tv, note: red yellow white composite cable will not interchange with blue green red component cable or connection.
simplify- blue green red= component
red white yellow=composite
*wires must match colors on both tv and player inputs.
then set your input on your tv to where you conected the cable.
Jun 15, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Just need to know where to plug in the red, green and blue cords
The red-blue-green outputs of the cable box are COMPONENT video, and the yellow-white-red inputs on the tv are COMPOSITE video. Although the words sound almost alike and the connectors look similar, they are incompatible signals. You'll need to change either the cable box or the tv so they match. Maybe this would be a good way to rationalize getting that new home theater system! Or maybe call your tv cable company and ask for a different box with composite video output. Once the cable box matches the tv, you don't necessarily need to change the cables. If the connectors fit, go ahead and use the cables you have.
Jul 15, 2008 | Quasar SP-3235 32" TV
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
