Question about Fisher and Paykel Refrigerators
Manual rf610adu freezer not working
Manual
Brad Goodale
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Possible thermostat faulty.
Posted on Jan 17, 2016
How does the Frigidaire FFU1764 Upright Freezer defrost?
Download its manual here and then read through the defrost section. It should run every 12-24 hours.
Aug 23, 2012 | Frigidaire Freezer 16.7 Upright Freezer,...
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
Fridge is not cooling
Check compressor is working. If working check freezer is working. If freezer is working with full of ice, check for auto defrost. If not, manually defrost it. In maximum units the main problem is fridge not cooling but freezer working alright. As over ice formed and covered up fan side (Behind Freezer), there won't be cooling in fridge compartment. Thanks.
Jan 27, 2011 | Samsung Refrigerators
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool gs2shaxnl00 freezer working but not fridge not
The possibility is that the freezer fan is not working or the passage from the freezer to the refrigerator where the fan blows the cool air from the evaporator is blocked. Also if you say you manually defrost it could be that it is not self defrosting which can also cause this problem because the evaporator will build up ice and block the flow of the fan air
Jul 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Lost the manual
try hoshi web sight. Has all manuals and trouble shooting guides. Good site to visit. You can print out your manual or save to your computor or disc
Feb 03, 2009 | Freezers
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Refrigerators Logo
74 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Muntejaya Ginting
Muntejaya Ginting
Geoff
NOEL
NOEL
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
