Three of my buttons around the center arrow buttons (the menu button,
the call button and the cancel button) will ALL work sometimes, then
when one of the three buttons don't work, then all three of them don't
work. I don't know if it's a circuit problem or if something is jammed
in the keys. When one of the buttons don't work, i try playing around
with them, like pushing one of the buttons for a long time, and
sometimes they work and then sometimes they don't. If I were to clean
the key pad (on top of the phone, not the number key pad) then how
would i do that? Do you think it's a circuit problem?
How do I take off the top part of the phone to access the keys? (the part that slides)How do I take off the top part of the phone to access the keys? (the part that slides)
AnonymousMay 09, 2009
My arrow and cancel keys work fine but the keys on the base of the phone(1;2;3 ect.) work but they take a while to respond. Maybe its a virus, i don't know. Please help.My arrow and cancel keys work fine but the keys on the base of the phone(1;2;3 ect.) work but they take a while to respond. Maybe its a virus, i don't know. Please help.
You can't post conmments that contain an email address.
button,the call button and the cancel button) will ALL work sometimes,
thenwhen one of the three buttons don't work, then all three of them
don'twork. I don't know if it's a circuit problem or if something is
jammedin the keys. When one of the buttons don't work, i try playing
aroundwith them, like pushing one of the buttons for a long time,
andsometimes they work and then sometimes they don't. If I were to
cleanthe key pad (on top of the phone, not the number key pad) then
howwould i do that? Do you think it's a circuit problem?
Contact problem more common with any phone. Simply problem, somtimes you have to take a part the phone clean it, dry it to fix that. You can buy a special cleanig solution for wather dammage from ebay if you realy want to fix this alone.
Service-mode functions
NVRAM initialization
An NVRAM initialization will return the following device settings to the factory-set defaults:
All menu settings, including the fax header and company name
Fax numbers and names that are associated with one-touch keys and speed-dial codes
Additionally, all faxes stored in memory are cleared.
Perform an NVRAM initialization
1.
Turn off the product.
2.
Simultaneously press and hold the
the product.
3.
Wait until the message Permanent storage init. appears, and then release the
arrow buttons.
When the NVRAM initialization process has been completed, the device control panel shows the
Ready message.
Super NVRAM initialization
A Super NVRAM initialization will return all of the device settings to the factory-set defaults (generic
product mode).
NOTE:
When the product is turned on, you will be prompted to select the language and country/region
setting before the product will initialize.
1.
2.
the product.
3.
arrow buttons.
Service menu
NOTE:
An asterisk (*) symbol next to a service submenu option indicates that this is the current setting
for that option.
For more information about using the service menu, see
Access the service menu
1.
Press the
2.
Use the arrow buttons to select Main Menu Service, and then press OK.
3.
Use the arrow buttons to select the desired secondary-service option, and then press the
button.
4.
Use the arrow buttons to select the desired submenu option, and then press
ENWW
Setup
button.
Cancel
button and the right arrow button
Cancel
button and the left arrow button
Service menu on page
), and then turn on
Cancel
and right
), and then turn on
Cancel
and left
241.
OK
OK
You can go to: www.sonystyle.com for support to download manuals. On you camera press the menu button. Use the control button arrow keys to scroll over to the wrench icon. Then continue to scroll over to page 2. Scroll down to the language bar using the cotrol button down arrow key. When the language bar highlights press the center control button to execute the selection. A menu will appear that you can scroll up/down with the control button arrow key to highlight your language. Then press the center control button to execute the selection.
Try the following steps to resolve the issue,
1.) Press & hold the * key
2.) press the # key & release both the keys.
3.) Display should say Enter Special Key Combo - Press & release in sequence 1,2 & 3 buttons.
4.) Press and release the right arrow button (or the right arrow icon on touch screen displays) to look for the System Configuration Menu then press OK. 5.) Press and release the right arrow until the Ink Initialization status is displayed.
6.) Press and release the OK button. 7.) Display should say Ink Initialization status: Clear. Press OK to set it.
8.) Press and release the OK button ONCE. (This is very important; do not press the OK button for a second time).
9.) Press the cancel button three times to leave the support menu.
10.) Unplug the unit from the power supply and wait 10 seconds. 11.) Plug in the unit, Follow the on-screen instructions, the unit will initiate the initialization cycle.
