Dyson Desk Fan Logo
Question about Dyson Desk Fan
Disassemble a dyson desk fan
12 inch air multiplyer
AskDyson
  • Official Brand Answer
  • 2,572 Answers
Hi there, it's Jack at Dyson.
We would strongly advise against dismantling your Dyson Air Multiplier desk fan any further than is shown in the User guide, as this could cause damage to the internal component and electronics. Additionally, it can also void your Dyson warranty if this is currently valid.
If you're having any difficulty with your Dyson fan, please contact us directly so we can provide further assistance. You can reach our experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Posted on Oct 20, 2014
1helpful
New Dyson AM09 hot/cool fan does not oscillate
S Adams, return for refund or replacement, sound like plastic gear inside could be damaged or loose. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.dyson.co.uk/support/am09/am09-white-nickel/my-machine-is-not-working/my-machine-is-not-oscillating
https://www.dyson.com/support/am0112/am01-desk-fan-12-silver-iron/diagnosis-root-menu/my-machine-is-not-oscillating-am01
Dyson AM 02 Fan not working oscillating feature is broken
http://www.dysoncanada.ca/en-CA/support.aspx
tip
How to clean your Dyson Cool fan
How to clean your Dyson Cool AM01 or AM06 desk fan, AM02, AM02 Living, AM02 Mini, AM07, AM07 Living or AM07 Mini tower fan, or AM03 or AM08 pedestal fan.
Your machine may differ to the one shown in the video, but the process for cleaning it will remain the same.
IMPORTANT: Please turn off and unplug your Dyson Cool fan before cleaning it. We recommend using a soft, dry cloth or soft dusting brush to clean the intake holes and loop amplifier. Do not use liquids, polishes or detergents to clean your Dyson Cool fan as this could cause damage not covered under guarantee.
on Nov 27, 2014 • Dyson Dryers
tip
Dyson Cool AM06 Air Multiplier desk fan - Getting started
How to assemble and use your new Dyson Cool AM06 Air Multiplier desk fan: adjust the power and oscillation, change the angle of the loop, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
on Mar 07, 2014 • Dyson Dryers
My Dyson AM01 is making a whining noise. How can fix it? (Calling Dyson's tech support only resulted in a small discount towards spending $300+ on a new fan!) Whines upon starting and will continue for...
Hi Tom,
I'm sorry you're having difficulty.
It is a very difficult thing to try and diagnose something like this without an inspection of some kind and I wouldn't want to speculate on the cause of the noise.
The only option is to speak to Dyson directly again. Please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
Best wishes,
Allan
1helpful
How do I disassemble a Dyson Cool AM07?
Hi Glennis, it's Jack at Dyson.
I've included our Getting Started guide for AM07 below. To disassemble it, you would just need to reverse these steps. To remove the loop amplifier, hold the main body firmly and twist
the loop amplifier anti-clockwise to unlock.This may be a bit stiff if the fan is brand new and hasn't been disassembled before.
I hope this helps, but if you need further guidance from our experts, just give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
2answers
Why wont my dyson fan oscillate?
Your Dyson Air Multiplier AM01 desk fan should oscillate when you press the oscillation button on the base:
If you find that it's not oscillating when this is pressed, we'd need you to contact our Support team directly - we can confirm if we're able to resolve this for you under our free 2-year parts and labour guarantee.
You can reach us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Where is the fuse for a comfort zone model cz121b ocillating desk fan?
I've never seen a fan with a replacable fuse. There may be a thermal fuse inside the motor windings.
Dyson AM01 fan can not on
Hi David, it's Jack at Dyson.
If your AM01 Air Multiplier desk fan doesn't seem to run at all, we'd appreciate the opportunity to take some further details - many issues are easily resolved with some troubleshooting checks over the phone.
In the event that we're unable to resolve the issue, we can confirm if a repair or replacement is covered under your machine's 2-year warranty.
You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
1helpful
2answers
Hi loss of suction on Dyson DC07 and I have changed the belt on the brushbar and cleaned all filters/removeable parts but still suction not very good, any other suggestions?
Check for a clog where the power nozzle connects to the hose. Clogs or leaks in the hose will both cause loss of suction/air flow. Another possibility is broken or worn out fan blades.
1helpful
P4 doesn't useful.
you either have to update your bois, or your new fsb speed is not supported by your mobo
Open Questions:
0answers
Lg dryer DLG1701W te1 and te2 codes blower thermostat keeps blowing as well Hello my lg dryer model number DLG1701W has been having issues for the past 3 days. Dryer finished a normal cycle and wouldn't start up again after swapping load of laundry out. When I tried starting it up again it was throwing a te1 code. Looked up the code on lg's website and tried doing a hard reset. Tried a few more times again and this time I was getting a te1 and a te2 code. Looked up the te2 code and decided to pull the machine out and inspect/clean the exhaust. Exhaust wasn't clean but air flow also wasn't restricted and the flaps on the outside of the house were on and in good shape. Hook the machine back up again and tried starting it again with attempting to reset again with no luck. I decided to pull the machine apart and test the thermistor with my fluke meter. found the thermistor on the exhaust side was reading but was all over the place. 13 ohms while in the machine. Down to 9 ohms when removed. After letting the thermistor sit for a little bit it was reading 11 ohms but was all over the place in that range between 11.08 to 11.96. Wasn't sure if that was normal or not so I decided to replace it. Tested the other thermostats while I was in there and found both thermostats on the gas range were reading normal but the thermostat on the exhaust side of the unit was faulty. Not reading at all. So I replaced the thermistor and the thermostat on the exhaust side. Button the machine back up and go to test but initally the same error codes were coming up te1 and te2. Finally after a few more attempts the dryer started. I had it set on a high temp 40 minute cycle. After about 10 minutes of it running though the barrel stopping turning and the gas range shut off. But it didn't throw any codes. The display continued to countdown and all the other light were working as if it was still running. Shut it off a few times and tried starting it back up and the same thing would happen. Countdown would display and countdown. All the lights would light up as if it was working but the barrel wasn't turning. And the gas range wasn't running. I walked away for a little bit to think about it (approximately 2 hours) when I came back to it, the machine was doing the same exact thing as what it would initially do. Click and display a te1 or a te2 code. I pulled the machine back apart again and currently still have it apart. The thermistor seems to be in a continuous 11.25 ohms range with the ohms dropping when touching the sensor it self. The thermostat that was just replaced has blown once again. Any insight on why this could be happening would be very much appreciated Update. Checked all the components again including the motor. Motor checked out good. Put everything back together again. Try it again a few times. This time everytime I tried it, the machine would start and run for a 4 to 5 seconds then shutdown and throw back the te1 and te2 code. Note: it never has both the te1 and te2 code at the same time. Each time it's tried it 1 or the other
See all Dyson Desk Fan Questions
Top Dyson Dryers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
NOEL
NOEL
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
