If it's the model I'm thinking of, it has a screw in filter cup up in the rear, upper right corner of the fresh foods section. Just twist that weird shaped cup on the bottom counter-clockwise and then pull down on it. It should come out with the filter in it. Then, just take out the filter, put a new one in, and then screw the filter cup back into place.
From a manual of a similar model to yours:
To change filter:
It is not necessary to turn the water supply off to change the filter.
1. Open freezer door and leave open until filter change is
complete.
2. Turn OFF side mounted ice maker by raising wire signal
arm to the UP position. Turn OFF rear mounted ice maker
by pressing ON/OFF power switch to the "O" position.
3. Hold filter cup firmly, and unscrew towards left (Some water
could leak out as you remove cup. This is normaL). Filter
cartridge should come down with cup. If cartridge remains in
housing, puli down gentl_; while twisting filter back and forth.
4. Rinse out cup under running water.
5. The large o-ring that seals the filter system fits in the o-ring
groove inside the cup. Should the o-ring fail out during filter
cartridge replacement, simply place it back in the groove
prior to screwing the cup back in place. If the o-ring becomes
damaged, you wiIIneed to order one from the Flectmtux
Solutions Hottine.
6. Discard old filter cartridge.
7. Remove new filter cartridge from packaging. Place in cup. The
end with the small o-ring should be up, out of the cup.
8. Screw cup, with filter, back onto housing. Do Not Use Wrench
To Reinstall Cup= Filter cartridge will self-align as cup is
tightened. Be sure cup is completely tightened with
PureSource TM logo facing outward. Do Not Tighten Past Stop.
9. Turn ON side mounted ice maker by lowering wire signal
arm to the DOWN position. Turn ON rear mounted ice
maker by pressing ON/OFF power switch to the 'T' position.
10. Check for Ieaks. Open refrigerator door. Wipe any water droplets
from the filter cup. Fi[Ia glass with water. If there is a leak,
unscrew filter cup, and reinsert the filter cartridge. Check
placement of large O-ring. Reinstall filter cup, making certain it is
tightened complete!_,_
11= To prime filter system and purge air from water line,
continue flushing the system for approximately 3 minutes
to assure that the purest water possible is stored in the
water tank. There win be noticeab[e spurts and sputters
as the system pushes air out through the system and
out the dispenser nozzle,This is normal.
SOURCE: how can I change the water filter on a frigidaire fridge
Hi, The filter is in the upper right hand corner of the fresh food section. Turn the filter cup counter clockwise to remove it. There will be a filter cartridge in the cup that you replace.
Please let me know if this has been helpfull or if I can assist you further
Thanks
Vic
SOURCE: changing the water filter in my Frigidaire
My Frigidaire PureSource water filter housing wouldn't unscrew either. Even with the supplied plastic "wrench" and later a cloth-covered pipe wrench, it wouldn't budge. Since both my icemaker and my door dispenser stopped dispensing water, and the filter housing in the fridge wouldn't budge, I suspected that the filter was full of frozen water. (Sometimes things on the top shelf of the fridge freeze, so it was obviously too cold.) I used a hair dryer on the water filter housing for a few minutes, and then the water filter unscrewed easily. Sure enough, the whole inside was a block of frozen water.
This would have been such a simple repair, HOWEVER unfortunately it turned out that I wrenched it too hard and broke the inlet valve on the housing. As soon as I thawed out the filter and reassembled, water was pouring out of the top. Took off the big cover at the top ceiling of the fridge and saw my problem.
It's only about a $25 part, but I'd advise that you be careful to only turn, without rocking back and forth, the housing when trying to unscrew. I guess I wiggled it back and forth too much and cracked it.
