Turntable sometimes works, sometimes does not. Have cleaned around it, made sure no food is under it etc.
SOURCE: Microwave model MV-1510M is not heating, also
If everything is working normally, except for heating, the likely cause is the magnetron. Microwaves can be dangerous to work on, as the site below points out. If you have an ohmmeter, it is possible to check the magnetron, but be certain to follow the precautions outlined at the webpage:
http://www.gallawa.com/microtech/mag_test.html
SOURCE: Microwave light comes on and
9 times out of ten it is the magnatron that has gone bad, that is the device that creates the microwaves for heating the food. Check inside the cabinet for fuses and if none found or blown then it is the magnatron. These are available widespread but most cost about as much as a new oven, so do a google search on your make and model of microwave and search for a magnatron for that unit. This will bring up parts suppliers and their prices and you can decide if it is worth fixing or replacing
SOURCE: LMA1560SB microwave--everything works fine (lights,
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
SOURCE: microwave turntable
The Turntable Motor will need to be replaced, a common issue with many brands.
