Question about DeLonghi Coffee Makers & Espresso Machines
No water coming out or milk coming out of spouts
Edward Harris
    Scholar:
    New Friend:
  • 78 Answers
This is a simple malfunction. Descale the machine one two or three cycles until the flow of water through the hot water pipe is with full jet.
The frothing will also be restored. If it does not, then you may need to clean the Milk stone clogging the frother. Milk stone is like cement and needs care and patience to clean without damaging the frother.
Good luck..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Posted on Oct 18, 2014
5 Related Answers
Anonymous
  • 944 Answers
SOURCE: spout for frothing milk pops out
You can get the user manual on this link if you need it; http://www.gaggiaparos.co.uk/ Check page 6 of the download, page 12 of the manual - the spout should just pull off and push back on. If it wont, then either something needs cleaning more, something is stuck in the tube or more likely the part of the nozzle that comes off, something is broken, or you need to use a little bit more force. If it appears broken, (check in particular for a fine crack that is only visible when the nozzle is stretched i.e. when in place. This type of plastic often will close a crack enough to be near invisible when not under tension.) then you could try gluing it although i doubt if this would work. You could just put a stainless steel hose clamp around it, tighten up just enough to make the nozzle spout stay on (bit of a pain, but may work). You can contact gaggia for a replacement - in the USA; Importika 596 Fishers Station Dr. 14564, Victor, NY Mr. Salzman Ph. 585.742.5178 Fax 585.924.1499 web site: www.importika.com e-mail: [email protected] Hope this helps - if you can post back a photo or two close up of the problem area, i may have more ideas :)
Posted on Jul 05, 2007
Anonymous
SOURCE: milk not frothing
Remove the black plastic outer sleeve of the Frothing Wand (some models have a metal outer sleeve). If done correctly, the “sleeve” has been removed, but the inner wand with red or black washer, is still connected to the machine.
2) The part of the sleeve assembly that you have removed is comprised of 2 pieces, the frothing sleeve and the center piece. The center piece can be seen if you look into the top of the wand.
3) Using a pencil (eraser end), or similar shaped object, push down on the center piece until an audible “click” is heard. The “click” means that the centerpiece is back into the proper position. When in the proper position, the center piece visibly sticks out the bottom of the sleeve about ¼-inch. It looks like a bird beak.
4) Now put the sleeve back on the machine and your machine should be ready to froth again.
As for the milk island, translaltion from the italian solution using google and drying all the parts works
Posted on Apr 30, 2009
Anonymous
SOURCE: Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Posted on Aug 12, 2009
Anonymous
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Posted on Jan 10, 2010
mnwarfield10
mark warfield
  • 452 Answers
SOURCE: I have DeLonghi ESAM3500. The
we repair 07779933829
Posted on Jan 21, 2011
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
Why does my coffee come out in drips not a continuous flow?
Your pump is getting weak. Pumps are made cheap now days and are part of a planned obsolescence program. That way you keep buying new coffee makers.
Oct 15, 2014 | Coffee Makers & Espresso Machines
Water does not dispense through the coffee spout
Did you cheak if the spots are blocked did you run some clean water ? The milk further is a different section from the coffee try and consentrat on the coffee part run some clean water is there any noise is the water going in to the trip tray because the spout are blocked ? Next go inside and cheak driver relay or seloniod stay safe if you not such don't do it
Jul 06, 2014 | DeLonghi Magnifica Coffee Makers &...
Delonghi coffee machine ecam23. Milk comes out of jug when turning machine on and milk also comes out after the water when cleaning the spout on the jug.
I think the ECAM has a second solenoid at the front near the milk jug. That solenoid valve might be stuck open.
>> service agent
Oct 17, 2013 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Initial set up of delonghi ESAM6700 and it will not go past insert water spout stage. Even when spout inserted it does not recognise and we cant continue setting up the machine as it simply reads insert...
OK, I can answer this one... the same thing happened to me. It would not recognize the water spout. No beep when inserted, but it would beep if you inserted the milk container. Looking into the receptacle, I saw that the switch for the milk container is offset to the right, and the switch for the water spout is offset to the left. All I had to do was carefully bend the lower tang on the water spout that activates the switch to the left a little bit. It looked perfectly straight, but was just offset to the right enough to miss the switch.
Hope this helps someone.
May 08, 2011 | DeLonghi Prima Donna Avante ESAM6700...
Delonghi Magnifica Coffee Maker the milk is not frothing properly - there's lots of steam & very little milk being issued from the spout We clean the milk jug each day, have adjusted the plastic tube...
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Sep 04, 2009 | DeLonghi Coffee Makers & Espresso Machines
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
EAM3500S will not froth milk ?
Here's what I did... with great success:
If you've cleaned all the milk deposits from around the o rings and you still have a problem then its almost certainly the milk spout (the little pipe that directs foamy milk into your cup)
Detatch the spout and get a 2.5 mm drill bit and use it to clean all the milk deposits out of the part that plugs into the lid. Rinse through with water to clean away all the bits of hard milk.
[If you put water through the spout before and after, you will notice a dramatic difference]
Doing this completely fixed the problem for me (I had about 3 years of milk build up in mine!).
Aug 16, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
441 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Jeffrey Groves
Jeffrey Groves
Charles Tidwell
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
