Question about Quantegy ADAT: ADAT: 60 Minutes ADAT (S-VHS) Tape
Tape torn near end. How to fix????
My Quantegy ADAT tape tore near the end, and I don't want to have to re-record all the music on it. How to fix a torn ADAT tape???
Thanks so much!
Posted by Kenade on
Anonymous
You'll have to open it up, but be very careful doing this. It can be done though, with a steady hand.
Posted on May 16, 2008
How to get rid of hum in output of my Akai 4000ds Mark II reel to reel tape recorder
I can't see this question answered anywhere. There is information for fixing hums on bother the Mk I and Mk II models of the Akai 4000DS here:
http://electronicaid.webs.com/
Sino ang kasama ko
Please do clean the head your VHS by using special head cleaner and check also your VHS mechanism and ensure it working well. If still problem, your VHS head is defective and suggest to replace with new one Regards, Jay
Can a 2 track reel to reel machine play 4 track tapes?
No it doesn't work.
A 2 track recorder is using bandsize /2, and a 4 track bandsize/4.
Regards,
Gerard
Can a 4 track reel to reel also playback 2 track stereo tapes?
yes depending on the machine it was recorded on tracks 1-3 will carry stereo sound if done on half track just plat it all four meters will come up
Reel to reel plays audio backwards
HAVE YOU TRIED TURNING THE REELS OVER? ON SOME PANASONIC UNITS THE REELS CAN BE PLAYED IN EITHER DIRECTION BUT THE SOUND IS REVERSED IF THE REELS ARE UP SIDE DOWN. TRY TURNING THE REELS OVER AND IT SHOULD STRAIGHTEN OUT YOUR AUDIO PROBLEM AS WELL AS BOOST THE VOLUME
[email protected]
What are the best tapes to buy to recrod from your reel to reel. I have some tapes that record and some don;t. Is it becaue they old or defected. Help me out. vp
maxell or tdk (which is hard to find now)....if your reel is 7 inch you want 1800 ft, normal bias (lo noise hi output) tape (for 10 inch you will use the 2400 ft) ....anything longer your tape will be dragging (both while recording and playing) hope this is helpful...feel free to rate
"prot" error message on Alesis ADAT 16 bit recorder
I heated the mechanical sensor switch with a hair dryer. Probably caused a contact point to expand just enough to close the circuit.
Tape drags toward end of reel
Unplug the unit.
You probably have a brake band thet keeps the reel from free spinning. It's located under the top cover plate of the tape recorder. The band is made of cork. Over the years, it probably just got a buildup of dirt. It can be cleaned off with rubbing alcohol. Don't pull on it, it will snap. The piece you are looking for will be located right under the left reel post.
2answers
Alesis lx20 type 2
send it to be serviced.
My adat lx20 keeps showing a error 2 and spits the tape back out, i chek the tape in my other adats and its fine. any suggestions?
Owain
Electronics - Others Logo
Top Quantegy Electronics - Others Experts
Ekse
Tom Chichester
Are you a Quantegy Electronics - Other Expert? Answer questions, earn points and help others
