Question about Black & Decker 750w Power Inverter
How do I replace the fuses in a 750 watt black and decker power inverter
Posted by bud_logo on
Anonymous
    Problem Solver:
  • 7 Answers
Look for a cover to maybe flip up or slide (most inverters fuses are coverd)
Posted on Jul 05, 2009
Manual for black and decker 1200 watt invertor
some idea for inverter, collect inverter circuit Books from market.
May 28, 2012 | Black & Decker Vector Cable Kit for 1200...
What's your problem?how many amps on a 1/2 horse sump pump
750 watts is pretty close to one HP. However, the pump will have a much higher current draw on start up which may be too high for the inverter. (The accurate number is 745.699872 Watts per Horsepower)
Discounting any losses, 750 watts from a 120 volt supply will draw 6.25 Amps. so 1/2 horsepower should draw 3.125 while running. Startup current may be much more. Check your pump for its current draw (should be printed on the pump) and check it against the inverter's limits. It may be that the inverter is too light for the pump.
Apr 28, 2012 | Black & Decker Husky 750w Power Inverter
I think i blew the fuse in my inverter by putting the cables on the wrong battery terminals--how to replace fuse
http://servicenet.blackanddecker.com/Parts/Search?searchedNumber=750%20Watt%20Power%20Inverter
There are around 8 models of the 750 watt inverter. The above web link takes you to the Black and Decker site where you can input your exact model number and then you can download the instruction manual which has the details for how to change the fuse.
Dec 28, 2010 | Black & Decker 750w Power Inverter
How do you change the fuse?
Most devices like this have the fuse inside the plug that goes into the cigarette lighter. The knurled silver tip unscrews. Caution that you don't loose the spring inside.
May 19, 2010 | Black & Decker Black Decker PI100AB 100...
Can I connect vacum cleaner big one with Black & Decker 100 Watt power inveter
No,
You will need a much larger power inverter than that to run that vac...
heatman101
Apr 22, 2010 | Black & Decker 100 Watt Plug-In Power To...
Describe your Black &
I have a black and decker 100 watt power inverter. When the led turns red you are ethier overloading it or it overheated. to fix it unplug it and let it sit for 5 minutes. Plug it in. Plug in an item rated for 100 watts or less. Or try to charge somthing on the usb port.
Aug 23, 2009 | Black & Decker 100 Watt Plug-In Power To...
Connection to car battery
The answer is yes...BUT make sure the polarity is correct and the inverter turned off when you make the connection
Apr 30, 2009 | Black & Decker 750w Power Inverter
Power hook up
This type of inverter has large alligator clips on it because the amperage that comes through a cigarette lighter is insufficient and can result in blown fuses and overheating of the socket. Hook this one up directly to the battery without splicing a longer wire to it.
Apr 22, 2009 | Black & Decker Husky 750w Power Inverter
Black & Decker 750w Power Inverter Logo
433 people viewed this question
Top Black & Decker Electronics - Others Experts
Sheldon Dedek
Vernon Taylor
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
