Question about Vizio Televison & Video
Visio tv will not turn on
Will not turn on
Deborah Pearce
    New Friend:
  • 21 Answers
Unplug for about 2 minutes. then plug back in. Should be able to turn on . If the batteries are weak in your remote,it will not turn on or operate.
Posted on Nov 26, 2014
How do I get my Sony universal remote to work with my Visio tv!
On your Visio TV remote control there will be a Source button or Input button. Press it & on your TV screen select HDMI 1 or HDMI 2. See the TV to see how the HDMI cable is connected from TV to Set Top Box. Now take the other remote control i.e. Sony Universal remote in your hand. Press mute & Select simultaneously. A blue light will blink twice, Immediately release the buttons & enter the code. You have to be extremely fast in doing this.
Following are few codes which you can try:
002, 000, 011, 080, 111, 006, 071, 128, 1904, 925, 0000, 0834, 0810, 1685, 1786, 1032, 1972.
Check the Visio TV manual for the make of your TV & model no & if code is printed. Then contact Visio TV manufacturer or retailer for the Visio TV code to enter & synchronize with the Sony Remote Control.
Nov 13, 2016 | Sony Televison & Video
Visio 1080p screen went light
Our Visio 42" flat screen TV did the same thing. It didn't happen that often but sometimes it would go darker or the sound would go off until I changed the channel or turned TV Off then back On. I contacted Visio through my warranty and they sent me a flash drive to install info on my TV. Did not fix the problems. A year later before warranty ended I contacted Visio again. They sent a huge box for me to pack my TV in to send to the warehouse where they fix everything. It took about 2 wks. to get it back. Worked fine for about 4 months and the problems continued. I will not buy another Visio TV. I found out that they had many problems with several models.
May 03, 2014 | Televison & Video
Visio tv turns self off
Check the AC power input for any loose contact. Check it with connecting to an other AC input.
Jul 14, 2013 | Televison & Video
Visio light on front flashes on and off tv won't come on
Unplug your TV and then plug it back in, let it flash on and off without doing anything for 5 minutes or so and then turn it on. It does it once amonth or so for some reason.
Nov 24, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
My Visio 50" Plasma Model#
Have you removed the back and looked for Bad Capaciotrs on the power supply board?
Capaciotrs will be vented or puffed up on Top. 1000uf 16v,2200uf 10v 3300uf 10v etc....
Feb 17, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
P42HDTV Visio Plasma TV. The picture is bad grainy/snowy.
Doing some warranty work for Visio, I ran into this same problem. I replaced the video and power boards, among other things. Turned out to be a bad panel, which isnt viable to replace. Best to get Visio to agree they made a lemon (as all their products are in my humble opinion) and have them send you a new tv, or even better, buy a tv that is NOT a visio. You can get great deals on LG and Samsung these days, both decent quality tvs.
Sep 02, 2009 | Televison & Video
How do you hook up the audio from Visio flat panel to SA EX 300
Wild guess. Is the TV volume turned down and its output set to variable instead of fixed?
May 17, 2009 | Technics SA-EX300 Receiver
Visio TV and Direct TV remote
I bought a 42" Visio LCD from Costco and used code 10030 and it worked. It is the code for Goldstar TV.
Nov 17, 2007 | Televison & Video
Televison & Video Logo
79 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
