Have checked the pump and that is ok. No water in the drum.
UNPLUG WASHING MACHINE FROM ELECTRICAL SOCKET.REMOVE BACK PANEL FROM WASHING MACHINE AND CHECK ALL BELTS ARE ON THE PULLEYS OR WORN AND NEED REPLACING. IF BELTS ARE OKAY REPLACE BACK PANEL AND REPLACE PLUG INTO ELECTRICAL SOCKET SWITCH WASHING MACHINE ON THEN TURN OFF AT WALL SOCKET. WAIT FOR FIVE MINUTES EXACTLY. PUT A TEA TOEL IN THE FRONT LOADER, TURN ON WASHING MACHINE AND PROGRAM TO SPIN RINSE, PRESS START BUTTON AND ALL SHOULD BE WELL. GOOD LUCK!
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
SOURCE: washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
SOURCE: bendix 800 autowasher de luxe, drum spin snagged then cleared.
should b nothing off this description on ure machine unless the pump coil has over heated iff so just replace coil and check for blockages
SOURCE: I have a Tricity Bendix AW1000W. The drum will not
Could be anything , from a loose connection or broken wire to a control board or timer fault..You say the brushes are o/k, but if they are less than 3 or 4mm long, they need replacing.
Even the motor itself could be faulty.
I assume the drive belt is o/k, and correctly tensioned..
It is difficult to advise you further because thier are too many variables involved.
Please leave your comments on my suggested solution.
Thankyou.
SOURCE: machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
