Question about Malber P21 Front Load Washer
Where in florida can I get a malber p21 washer and get the dementions of it. I have one in NY and love it
    New Friend:
  • 81 Answers
A Malber P21 has the following dimensions:
Height:33 1/2"
Width:23 1/2"
Depth:20 7/8"
(From the AJ Madison Web Site)
The model is discontinued, though.
http://www.ajmadison.com/cgi-bin/ajmadison/P21.html
The current model is the P31.
It's an Italian model sold primarily in the New York area.
You may want to call Malber at 516.323.5299. or email [email protected]
Posted on Oct 17, 2014
5 Suggested Answers
Dov Dror
  • 641 Answers
SOURCE: bleach/fabric softener compartment
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Posted on Sep 06, 2007
Anonymous
SOURCE: washer is jumping extremely only when spinning
I own a Malber WD1000, which is several years old. Recently, I had it transported a couple thousand miles across country, and due to the size of the pickup truck it was in, the machine had to lay on its side for the duration of the trip. Shortly afterward, the machine began making a loud banging noise during the spin cycle. Additionally, the door gasket had a "wrinkled" appearance.
After taking various panels off of the machine, I discovered the culprit. The insides of the machine (drum, etc), are more or less suspended inside the outer housing. This is accomplished by means of a pair of shock absorbers on the bottom, and a pair of large springs on top. This allows the inner workings to shake a little bit during the spin cycles, without transferring the vibrations to your floor. In my unit, one of the upper springs had come loose from the frame. The solution involved tipping the machine on its side, with the top cover off, and pulling the end of the spring back through the mounting hole in the frame, then finding a nut and bolt to occupy the additional space in the hole, so that the spring could not slip back out. Getting the end of the suspension spring properly seated again was no small task, but it solved the problem, and now the washer works just great again.
Long story short, I'd check to see if all the springs are in the proper place.
Posted on Apr 01, 2008
Anonymous
SOURCE: Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 washer on board a boat and it will not spin out the water. It is spinning but the water remains in the tub
Posted on Feb 19, 2009
Anonymous
SOURCE: I NEED A NEW HOSE
I'm a general contractor. I made up a new hose by using various couplings
and a speedy connector.
Posted on Jun 29, 2009
Parthasarathy
  • 80 Answers
SOURCE: my malber washing machine p21 will not turn on it is making a clicking sound but nothing else
It might be due to the switch problem or wire will be cutted for that which runs the engine... Check the wiring and switch on the machine..
Thanks
Posted on Apr 01, 2012
My malber washing machine p21 will not turn on it is making a clicking sound but nothing else
Thanks
Apr 01, 2012 | Malber P21 Front Load Washer
I have a Malbe P21 I reciently discovered the warm water is not coming in.. I checked the wall valve and its ok..
either the hot water solenoid is w/o power or is defective and you need to check its coil for power and then coil continuity,if some warm water is getting by the valve your washer screen in the hose may be plugged,replace them both,hot and cold
Feb 14, 2010 | Malber P21 Front Load Washer
I have a used malber p18. all the hoses are
Ok. Assuming that the water is turned on, and the electricity is ok it should fill, if not check is machine dead or able to function in other ways if alls ok then replace the solonoid valves that allow water to enter..Hope this helps.
Nov 27, 2009 | Malber P21 Front Load Washer
I NEED A NEW HOSE " Y - INTO ONE. WHERE CAN A GET ONE? I HAVE A MALBER P21.
Jun 25, 2009 | Malber P21 Front Load Washer
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dec 02, 2008 | Malber P21 Front Load Washer
Door handle
I have done this myself, breaking same part and fixing. For parts call 718-767-7396 in NY. I hope they will ship to you if you are not in NY. Good luck!
Jan 16, 2008 | Malber P21 Front Load Washer
Malber P21 won't empty...
noif water is gussing out when u puy the drain hose low to the ground then your pump has gone a way to check this without any water in the tank take of your outlet hose u will see a little fan inside the pump put it on empty get a screw driver and carefully place on the fan if the fan stops then it definetley neds replacing sorry love all u can do
Aug 22, 2007 | Malber P21 Front Load Washer
My washing machine won't fill with water
I have my washer connected to the kitchen sink. In order for it to fill I have to connect the hose to the faucet and turn it on, it is pain but that is the only way it will work for me. I hope this helps.
Sep 15, 2006 | Malber P21 Front Load Washer
Malber P21 Front Load Washer Logo
135 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
Jason Harris
Jason Harris
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
