Holley 0-4412S Model 2300 500 CFM 2-Barrel Manual Choke New Carburetor Logo
A
Anonymous Posted on Oct 17, 2014
Adjusting a Holley 2 barrel carburetor at altitude of 6500 feet
It's mounted on a Chevy 350 engine. I need to know how to adjust it for my altitude of 6500 feet.
pstockton83
Level 2:
Sergeant:
  • Expert 272 Answers
  • Posted on Oct 17, 2014
pstockton83
Expert
Level 2:
Sergeant:
Answers
272
Questions
0
Helped
56507
Points
823
Carburetor choke adjustment
On the choke coil are two screws, loosen them slightly, There are index marks between the screws on the housing, The factory setting is half way between the two screws. Turning the housing to the right allows more fuel, to left is less. Don't over adjust, start slow with movement of the housing, tighten screws and test. Make sure it is cold when you do any adjustments.
Where is the pcm/vcm location on 1999 chevy tahoe?
Shift the vehicle's transmission into park (automatic) or first gear (manual transmission). Turn off the engine, then rotate the ignition back to the "ON" position, but do not start the engine.
Connect the scan tool's data communication cable to the vehicle's diagnostic data port underneath the dashboard, above the foot well area.
LET ME KNOW THIS HELPS
2helpful
Living Air XL-15 Classic - Foul odor!
Hi cant standit,
Can you control this odor by adjusting the ozone (O3) control? High levels of O3 smell obnoxious or irritating to some people; you want a fairly low concentration (~40 ppb - that's parts-per-Billion, not much).
It sounds like you've done everything else right. Have you consulted with the dealer you bought from? How about EcoQuest? If it's not the O3 level being too high, then perhaps there's something goofy with the unit. If it's under warranty, pursue that option. You should have contact infor with the unit; respond if you need it and I can post it.
Let me know.
1helpful
3answers
XL15
The ozone plates need to be cleaned monthly to work effectively. You can get an owner's manual for free from the manufacturer's website, it's at:
http://www.ecoquestintl.com/support/US50300_Living_Air_Owners_Manual.pdf
The manual has a description of the type and frequency of cleaning of various parts of your air purifier. Hope this helps!
Top Holley Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Holley Air Purifier Expert? Answer questions, earn points and help others
