When the vacuum is on, it makes a loud noise which it never did before...what could possibly be the problem? and should we be using it?
SOURCE: too loud noise of Bissell 6590-W vacuum cleaner
When they get real loud either the motor bearings or the motor fan are bad and you will have to replace the motor, part #2031100, would sell for about $45.
SOURCE: Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
SOURCE: My bissell momentum vacuum is making a very loud
it might be the motor or the fan is messed up.have someone or you check that out.
SOURCE: how to use bissell proheat clearview 12 amps rug
Here is a user guide, and it will show you how to use it. just click and read. its a PDF file. you might need adobe to look at it. It is a free download.
http://www.bissell.com/images/UserGuides/7901_1008.pdf
Hope this helps you from sawdust
SOURCE: Vacuum sounds like an airplane after 1 year of use.
the motor bearings are starting to fail most likely. You can diagnose the source of the noise by removing the brushroll and belt, could possibly be the brushroll bearings but if you still get the noise when the belt is off its the motor.
