Sewing Machines Logo
A
Anonymous Posted on Oct 16, 2014
Why is my juki machine 8700 not moving at 3000 speed
Andrew Steipp
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 63 Answers
  • Posted on May 04, 2015
Andrew Steipp
Contributor
Level 1:
New Friend:
Night Owl:
Answers
63
Questions
0
Helped
15492
Points
75
Do you have a clutch motor or a servo motor? If a clutch motor check belt tightness. It could be slipping or too tight. If a servo motor, check the speed setting on the motor. There Is a knob to adjust the speed setting on the motor.
sew king
Level 2:
New Friend:
  • Expert 64 Answers
  • Posted on Mar 07, 2015
sew king
Expert
Level 2:
New Friend:
Answers
64
Questions
0
Helped
19661
Points
101
Want speed change motor pulley to larger size. larger belt from auto store.
William Gilbert
Level 3:
Master:
  • Juki Master 470 Answers
  • Posted on Feb 15, 2015
William Gilbert
Juki Master
Level 3:
Master:
Answers
470
Questions
0
Helped
115908
Points
2377
There are several manuals available, depending on detail and complexity:
JUKI DDL 8700 Manuals
5 Related Answers
ken dourof
  • 980 Answers
  • Posted on Oct 29, 2009
SOURCE: Hi I have 5 Juki DDL-8700-7 machines and I need to
So many machines you would be best at aution as one complete lot.
ken dourof
  • 980 Answers
  • Posted on Nov 05, 2009
SOURCE: is there a simple way to slow the speed down on a
On the motor where the clutch is you will see thge large pin with a nut on it, as you press on the pedal the pin engages with the motor, if you loosen the nut and unscrew the pin bit by bit and try the machine you will get to a point where you will have absolute control on the speed.
abozid
TCHNICAL SUPPORT FOR JUKI-JACK-PEGASUS
  • 180 Answers
  • Posted on Feb 19, 2011
SOURCE: I need to change the
hi there
how come tere doesn't seem to be a tray under the machine ? pleasemake sur your machine come with oil pan ( could be come with oil pan ). or maybe your are talked about other model.
please follwo this steeps to change oil for your machine if it come with oil pan:
1 - back head of machine to back said.
2 - you will found oil pan and in right said you can see screw for empty old oil please put any bottel under oil pan and remove that screw until oil is come down .
3 - try to clean oil pan with any dry material and rethight the screw again.
4 - but new oil on oil pan until arrive to high level and turn ON you machine any running it for arround 10 minutes to make oil goes throw all tubes insaid machine.
best regards
ashraf abozid
CAIRO -EGYPT
chris592
Chris DeWitt
  • 86 Answers
  • Posted on Mar 12, 2011
SOURCE: I just received my Juki
There should be a bobbin winding device next too and slighlty behind the drive belt.
Should be like this bobbin winder.
abozid
  • 180 Answers
  • Posted on Aug 26, 2011
SOURCE: how solve Juki DDL 8700 automatic single needle
hi there,
1- check V belt if there's more loose plase make it tight littel.
2- check timming cam for thread trimmer , sometimes lock after trim and E7 appear.
please advice me type for control box ? i can give more help if you have basic knowledge for electronc. just email me if you want any time.
best regards
ashraf abozid
[email protected]
CAIRO - EGYPT
1helpful
Error Code on Juki DDL 8700 Machine - E1 or E001
If it is only 90 days old it is under manufacturer warranty. Contact them for a free replacement.
They don't list an E1 Error
https://www.manualslib.com/manual/522984/Juki-Ddl-8700.html?page=40#manual
Product Registration
Juki Home https://www.jukihome.com > warranty
If at any time during the applicable limited warranty period, the product is determined to be defective JA will replace or repair the Product, at JA's option.
Doesn't include: 8700 ‎' Must include: 8700
  • FAQs
    https://www.jukihome.com > faq
    For a limited warranty period of two years on motors, light assembly, wiring, switches, circuit boards, and speed control; and for a limited warranty period ...
2answers
Juki DDL 8700 Lockstitch Sewing Machine doesn't connect the foot pedal to the needle.
Since you took the sewing machine apart, i believe that the reconstruction process was missing a step.
You might check that the belt was placed according to the steps in your product instruction manual. It might have been accidentally placed in reverse.
After that I would use those instructions to start double check that you put together your sewing machine properly after your move.
Thank you.
I have a juki ddl 8700 machine all of a sudden it stop working. Every thing is locked and is not moving at all. What should I do? Please help.
Answer to 8700 locked up. I had a Juki 8700 do this. I was the needle bar it overheated and expanded. About 25 for new needle bar. Also increase the oil to the needle bar.
Stretch stitch juki 8700
Hi there, no you cannot do a stretch stitch on the ddl-8700. It only has on stitch and it is a straight lockstitch.
How can i stp my juki 8700 had wheel from sticking
LOL
You can take it in for cleaning and oiling. The hand wheel sticking is a symptom of it needing service.
2helpful
2answers
Obtain Juki Industrial User's Manual 8700-7
hi there
u can find at www.juki.com under industerial sewing machine
u can download DDL 8700-7 instruction manual
best regardes
ashraf abozid
[email protected]
3helpful
2answers
Is there a simple way to slow the speed down on a Juki DDL-8700??? My friend wants to sew, but it is way too fast for her .........any help would be appreciated.
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
