Question about Spirit ® XT375 Folding Treadmill
Need 2 x brushes for XT375 Spirit Treadmill
Need 2 x brushes to the motor of above treadmill. Please kindly reply [email protected] The treadmill is desperately needed to start working in a gym as currently it's down.
Posted by Kamlesh Kumar on
Thomas Beaver
  • 2,119 Answers
5 Related Answers
gdcroft
  • 192 Answers
SOURCE: Your Problem: Spirit Treadmill motor will not turn on
I'd start by attaching a voltmeter across the motor contacts to see if you get any voltage when the unit is turned on. It's probably an AC motor but I'd check the label to be sure. If you get voltage but no turning either the motor or a startup capacitor is bad. If this is the case try moving the tread by hand with the unit turned on. If it moves on it's own after you start it moving then the start up cap needs to be replaced. Otherwise it may be time to replace the motor. If you don't have voltage across the motor contacts when the machine is turned on, I'd unplug the unit and trace the lines back from the motor to somewhere on the PC board. I'm guessing there's probably a relay on the PC board that controls the motor. I'd use an ohm meter to make sure the relay coil hasn't turned into an open circuit. Next I'd put a voltmeter across the relay coil, plug the unit back in, and turn the treadmill on and off several times. Ideally you should see the voltage across the relay coil go up and down as you turn the treadmill on and off. This voltage could be AC or DC depending on the type of relay used. If you get the proper voltage across the coil but the relay contacts aren’t' opening and closing to provide power to the motor then you need to replace the relay. If you don't get the proper voltage across the relay coil the problem is further back on the PC board.
Posted on May 15, 2009
Anonymous
SOURCE: WANT TO REMOVE THE MOTOR FROM SPIRIT TREADMILL TO
Remove cover at front of treadmill,4 pillips screws on each side, 2 screws at front. Lift off plastic cover. Loosen motor belt tightener at top of motor mount ,remove 4 11/16 " nuts holding motor to treadmill base, remove red and black motor wires from control board. Lift motor out.
Posted on Aug 05, 2009
Anonymous
  • 64 Answers
SOURCE: need manual for spirit sr175 treadmill
Call Spirit @ 800.258.8511.
Posted on Nov 17, 2009
Anonymous
  • 79 Answers
SOURCE: How do I download a manual for a Spirit Fitness Z500 Treadmill
http://www.spiritfitness.com/ownersmanuals.asp just keep it in a folder and go!
Posted on Feb 09, 2010
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: Treadmill powers off when pressing Incline Increase "br 1" error
You may have a beltand deck problem. Test by the following procedure:
without the poweron stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time
Posted on Jun 13, 2010
My belt is lubed and properly tightened. The belt will slow down intermittently randomly while running without anyone on it. Model NTL2495.0
first of all check the drive belt is loose or not. Drive beit connect with the motor and roller of the treadmill. its not possible to see the drive belt out side. you can only see it if you remove the motor cover. if its loose the try to tighten it. if its not the problem then the treadmill motor have some problem. Either the motor is faulty or the carbon brush is faulty. There is 2 carbon brush inside the motor which is replaceable, its used to take the voltage to the rotary part (armature) of the motor. If the contact with the rotary part and carbon brush is poor the this type of problem can occur. tyr to change the brush. Here i have added a video which demonstrate how to change the carbon brush of the treadmill motor. It not the exact model you have. but almost all treadmills have the same type of motor. even after replacing the carbon brush the treadmill shows the same problem then you have to charge the motor with a new one .
http://electro-medical.blogspot.com/
Fitness repairs
Nov 13, 2015 | Exercise & Fitness
How do i fix an e2 error and get a wiring diagram
Dear Sir:
I will try to help you, please be patience and carefully, use basics tools:screwdriver, hex,allen, Dvom.
Troubleshooting: ERR2 - Motor Movement
Since the motor moves when you press speed up, focus on the optic sensor, its wire connections, and the
optic sensor wheel. If all seems well at the sensor, inspect the motor.
Optic Sensor
??? Optic sensor wheel - Make sure that the optic sensor wheel rotates securely, without wobbling, in the
middle of the optic sensor. Realign and tighten if necessary. If optic sensor wheel teeth are missing or
bent, replace the optic sensor wheel.
??? Optic sensor wires - Make sure that wires are inserted securely to the optic sensor and to the drive board.
Check wire continuity.
??? Optic sensor - Turn on unit power. Turn the motor flywheel with your hand. The optic sensor
indicator (LED10, drive board) should light. . If it does not light, and all parts above are
good, replace the optic sensor.
Motor
??? Motor arcing - Does the motor show signs of wear - irregular arcing, carbon dust?
??? Motor brushes - Do brushes show signs of irregular wear - cracks, dents, lines? Replace the
motor brushes.
??? M+ M- Wires - Make sure wires are connected properly.
Other
??? Display main IC - To ensure proper signal processing, press down on the main IC on the display
board, marked U5. .
??? Ribbon cable - Ensure that the ribbon cable is attached at the drive and display boards. Check cable
continuity.
If you need additional help, please reach me.
sincerely. God bless you.
E.CUADR
MANAGUA, NICARAGUA
Oct 21, 2011 | Proform 730 Folding Treadmill Model...
Motor immediately shuts-down upon start-up
check the brushes, if the machine turns on normal but the engine does not work can be a problem with the brushes, check the connections or wires that go to the motor drive card. Also check the speed sensor is often a magnet
Feb 05, 2010 | Bodycraft TR1180 Light Treadmill
WANT TO REMOVE THE MOTOR FROM SPIRIT TREADMILL TO SEE IF IT CAN BE FIXED. HOW TO ?
Aug 04, 2009 | Spirit Exercise & Fitness
Spirit ® XT375 Folding Treadmill Logo
164 people viewed this question
Top Spirit Exercise & Fitness Experts
gbob59
Marvin
Marvin
john h
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
