Check the ground points. You don't need a cluster. The cluster will not turn the radio or anything else off. I don't have the ground points for the f150. You can probably find them online. Since you're having problems on the inside, look under the dash. Common points are at each side of the cabin area by the side kick panels. Also around the steering column. Any black or black/white wire will be a ground. Since the truck keeps running, the grounds under the hood are probably fine.
