Lol sounds like you tripped the pic in pic option.. the blue screen would probably be the feed from dvd or one of the other input options . Good luck I did that years ago and it took me forever to get out off... and a case of beer later... I think it had something to do with the pvc button on the remote.... stands for preview channel. so you could watch one and keep an eye on the other
SOURCE: i have a mitsubishi vs 50707 projection tv, sound but no picture
Is
the Lamp ok? Go to the rear of the set and turn on the set with your
remote while looking at the vent slats. If you can see a bright light
through the vent slats then your Lamp is working. If the lamp is on and
you have sound and no pix, then the Digital bd is in what we call
"Video Mute" and will have to be replaced. Also make sure that the Lamp
Door is installed and the screws are tight
also check to ensure the following.....
1. re-seating the DVI cable on both sides
2. Check to be sure the lamp door sensor is closing (that is not your issue but i thought i would post the complete answer)
3. Check colorwheel is spinning up (should be a low hum, and not sound like a fan)
*** it is very possible it is a failed colorwheel, but the set should go into shutdown, so it is probably not the issue.
4. If the set has sound but no picture replace DMD board....
If
the set is working and then just stops working best bet is the DMD ( i
would not replace just the dmd it is cheaper in most cases and much
easier to replace the lightengine) but if the set just is not working
and just failed and is now always not working best bet is the digital
board.
If you have an osciloscope you can measure the video
signal from the Digital board and see if it is present with the no
picture, if it is then it is a bad DMD but if the video signal
disappears of then you have a failed Digital board. You can not us a
computer USB scope, they can not read most of the data from the digital
board since they use multiple scan rates and wont trigger on them for
some reason, a old school scope works best i have found, or one of
those new LCD scopes that have an auto trigger work well i have found
that it is all i use anymore.
you can find a service manual with schematics at a very cheap price at ebay......
regards
iversh
