Question about Refrigerators
How to reset Panel for PFSS6PKW bottom freezer GE Profile Refrigerator? When power went off display is just showing 88 88.
We unplugged the refrigerator from the outlet and we flipped the circuit for the refrigerator - neither reset the water and ice display panel.
Bill Myers
    Sergeant:
  • 251 Answers
Try pressing and holding the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 or 15 seconds. It should give you and audible beep and reset the panel.
Posted on Oct 18, 2014
5 Related Answers
Anonymous
  • 1056 Answers
SOURCE: GE Profile PFSS6PKWASS ice maker quit, water and
Try defrosting it completely then re start it again. Shut off the water suplly. Maybe the service guy forgot to turn the water supply off.
Posted on Jul 07, 2010
Anonymous
  • 116 Answers
SOURCE: Temperature and adjust refrigerator panel does not work.
problems exist in its electronic control panel that is damaged, this problem should be solved by replacing one block electronic circuit in the control panel. damage is usually caused by a memory of the troubled program. actually if you know you can fix the electronic control panel of the electronic circuit itself, simply replace the IC EEPROM or memory alone. follows with Cristal oscilator usually must be replaced too
Posted on Jul 24, 2010
Anonymous
SOURCE: GE PFSS6PKW Displays 8888
Simply press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel.
Posted on Apr 11, 2011
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: GE Profile Bottom Freezer Refrigerator
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on May 05, 2011
Anonymous
SOURCE: GE PFSS6PKW display shows "88" on freezer side and
my fridge had the same prob thank you very much this really works i pressed the energy and alarm for 10 seconds and works PERFECT
Posted on May 10, 2011
My GE Profile refrigerator disolay panel inside is off, all blank. The ice&water dispenser on the door is not working but the display lights are. There is a tick tick noise I never heard before comming...
Power Resets
https://removeandreplace.com/2016/02/02/refrigerator-display-panel-is-blank-not-working-how-to-reset/
or
Refrigerator - Dispenser Control Panel Not Working
products.geappliances.com > gea-support-search-content
SAVE UP TO $2000 on Select GE Profile Appliance Packages ... Unplug the refrigerator or turn it off at the circuit breaker for 30 seconds to reset the control. ... Try resetting the control panel by turning off power to the refrigerator briefly. ... For service, please schedule an appointment with GE Appliances Factory Service.
Pfss6pkw drain plugged
Unplug your refrigerator and remove items and shelves from the fresh food section. Not sure about what nutdriver so try a 1/4 inch nutdriver first and remove the screws holding panel number 98 in this photo HERE The beginning of the drain hole for the fresh food section is below the evaporator and in the center bottom of location number 96 in that same photo HERE For the freezer drain it will be behind panel 47 in this photo HERE You will only need the to remove the fresh food section panel ocation 98 and the freezer panel location 47 to clean these two drains. I have a video from You-Tube that shows where to clean out but his refrigerator had the drain visible without removel of these two panels. In most cases the drain cannot be seen without removal of the panels. I am here should you have questions Thanks Sea Breeze
1helpful
2answers
I have a GE Profile refrig with bottom freezer.Today, the power company turned off the power to the streey and when power came back on, my display in the left refrig door is brinking 88 on one side and the...
I had this issue after a power outage with our GE Profile Model GFSF6KKY Dispenser Model. No solution that I could find online helped me so I started trying different button combinations. Pressing Adjust Freezer and Adjust Refrigerator buttons at the same time and holding it for at least 10 seconds worked for me.
30helpful
3answers
18helpful
2answers
Panel showing 88 88
You can try unplugging , wait a few minutes , and plugging back in . If that doesn't work , then the main control board , located on the back of the refrig ( behind an 8 " X 10 " panel ) , was damaged by the power surge , and needs to be replaced .
17helpful
2answers
Dispense panel blinking 82-88 on right - left - steady 88 - unable to reset - water only dispensing
Hold Energy Button & Light Button for 10 seconds!! No repairs needed. Solution is not in manual.
My GE Profile bottom freezer and frig's temps are also up..help
has a FF error shown up on your display. If so that is your freezer fan, and if not it still might be the FF motor is running to slow.
Refrigerators Logo
Top Refrigerators Experts
Dan Webster
Dan Webster
john h
