Question about RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
I am not getting any audio (sound) out of my Integra DTR 4.6. Any suggestions?
There is absolutely no audio coming out.
Billy
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
Does the vu meter show anything(bars moving up and down when audio is present?If so you may have a blown fuse or bad IC in the amplifier section causing the problem. If there is no indication of audio on the front panel it would be a Microprocessor problem
Posted on Nov 24, 2014
I have an Integra DTR 20.3. Recently, I have been getting no sound from the speakers after removing the headphones from the headphone jack. Any ideas?
Usually the headphone jack has a contact that's "made" by the 'ring' section of the jack when you push in the plug, which bypasses the speaker circuit (that's what automatically silences the speakers when you plug in the headphones when there are no switches to turn the speakers on/off manually)... if the 'ring' strip got bent somehow so it's pressing against that contact all the time, it won't let the speakers' circuit come out of bypass. Look inside the jack with a flashlight... the sideways Vs that touch the 'ring' sections of the stereo headphone plug should be about in the middle of the opening... if they're pushed over too far it may require disassembly to bend them back to the proper position.
Mar 08, 2015 | Integra Dtr-20.3 THX Select2 Plus AV...
"handshake" between DTR 5.9 and an LG Blu-ray player
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
How do I set up an Integra DTR 7.8 for 3D display and audio
Your DTR-7.8 receiver is not 3D compatible. It does not support the new 1.4 HDMI. You have to have 1.4 HDMI and 1.4 cables for the 3D format.
You can bypass your receiver for the video though. Simply run your HDMI cord (1.4) from your Blue Ray to your Projector. Your audio can be ran from your Blue ray to your reciever.
May 17, 2012 | Integra Audio Players & Recorders
I am missing the remote for an Integra DTR 5.3 receiver/amp. I have a Sony RM-AV3100 Universal Remote that I want to program to control it. Does anyone know where I can find the 4 digit remote code that...
Hello
Sony RM-AV3100 remote has no codes to setup with any Integra devices. You have to try its code search method. Sometimes you may find a code. But not sure. Go to the user manaul of that remote. There is proceedings for code search process. The codes are four digits indeed. OK.
Oct 09, 2011 | Integra DTR-5.1 Receiver
The reciver dosnt get a signal from the hdmi inputs both ps3 and blu ray have the same problem it is a dtr 5.9 integra
what you should do is make sure that your HDMI is cord is not in an awkard position, which like mine i have to unplug and plug back in to get a signal
Mar 01, 2010 | Integra DTR-5.1 Receiver
Doing a job for a friend. Reconnecting all his gear to an Integra DTR-7.1. Everything works except for the surround. I can't get the rears to speak from the receiver. I have verified they work (wires...
if you have everything connected properly, then it wont necessarily utilize ALL of the speakers, unless you have a true 7.1 signal coming in. is it using optical or coaxial? make sure that the options on the receiver are set right......the rears on 5.1 and 7.1 dont work unless they are told to by the receiver....and the signal coming in from the external source ( dvd player, ps2, ps3, xbox....) tell the receiver what it is going to need, in order to utilize the full signal. everything is labeled, and it sounds like you know what you're doing, when it comes to hooking this up, which is always good. it sounds to me, like something isnt configured properly, so i would start there. it may take a while, but you get the idea.....
Sep 24, 2009 | Integra DTR-7.1 Receiver
Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Jun 30, 2009 | Integra DTR-5.2 Receiver
No sound from speakers from components with Integra 6.9 receiver
Turns out it had to do with one of the settings for the new Blu-Ray player.
Thanks anyway.
Jan 17, 2009 | Integra DTR-9.1 7.1 Channels Receiver
RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat Logo
307 people viewed this question
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
